Ignition switch replacement
My 1991 F-150 truck (no tilt steering) will not start. When turning the ignition lock there is no resistance and it's not engaging in the start and run positions and hence won't crank the starter. It just rotates freely and does nothing. Jumpering the battery to the starter solenoid will crank the starter so I think the problem is the ignition switch. I replaced the lock and tumbler and that did not fix it. I bought the electrical ignition switch and cannot seem to get to it in the steering column. I've taken the steering wheel off already. Any help with this problem would be appreciated. I read a few other posts talking about an actuator??? Where is this? When turning the ignition lock a metal half circle looking thing moves in and out. Don't know if that's the actuator.
Put your steering wheel back on and pull the lower dash shroud under the column (4 twist fasteners) and the column shroud (1 screw on the bottom). Then you'll be able to see the operating rod running down the top of the column and the ignition switch under the dash above the pedals. See if the rod moves when you turn the key. If it doesn, change the switch. If not, let us know & someone will post further instructions.
Today at work I fixed a 1989 F150 with the same problem. The actuator was broken. It is a metal piece that basically connects the gear on the end of the ignition lock cylinder to the rod that runs down to work the switch. I could try to post instructions here on how to change it but I really think you'd be better off with a good manual with pictures etc. You have to dismantle the tilt column to replace it. It's a bit of a pain in the youknow.
hanna5120
1999 to 2016 Super Duty
01-31-2016 01:13 PM
fastcat1977
22
01-30-2016 09:04 PM
shadetree enthusiast
09-18-2014 03:39 PM
