1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Help - VSS, Speedometer
Old 06-11-2012, 02:19 PM
northsantiam's Avatar
northsantiam
northsantiam is offline
Copy that nogo, I was going off what I had read on this forum about where the speedo picked up its signal, but in the end it was the water in the GEM that was causing all the havoc. Now just trying to find where the water is coming from.
  #32
Old 06-11-2012, 03:50 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Originally Posted by northsantiam
Very time consuming and frustrating. I could only produce water after a heavy rain, I think i am down to the weather stripping on the cab near the rear door corner. No matter how much water I put on it either through a hose or sprinkler I cannot get it to leak. I sprayed windex along top of door onto weather stripping and then used low pressure shop air along inside of door and could produce bubbles in one location in weather stripping. Don't know if this is a good way or not but trying anything at this point. I am down to replacing the weather strip and/or reseal front windshield.
The usual culprit is a leaking windshield. The location of the GEM is prone to trap water if the windshield seal is leaking.
Originally Posted by nogo73
I am not sure by reading this but the vss is on the transmission not the differential. ABS sensor is on the differential. I just changed out all my gauges with autometer.Their speedometer needed a clean signal from the transmission in order to work.
The VSS and ABS sensor for the rear axle are the same part, located on the differential housing. The transmission has TSS (Turbine Shaft Speed) and OSS (Output Shaft Speed) sensors. (Assuming 4R100 transmissions....)
  #33
Old 06-11-2012, 10:06 PM
northsantiam
Thanks shake-n-bake for the info on the sensor. Pretty sure it is the windshield, after washing the truck today found a drip on the "A" pillar, I left the plastic off so I could monitor. After spraying upper right windshield I could get water along edge of window seal and it then travels down to "A" pillar where it looks like it travels down between 2 pieces of steel that make up "A" pillar and then seeps out the bottom of "A" pillar, which in turns puts the water straight above the GEM, it first drips down onto the small defroster tube leading to left side of dash for window. From there it can drip down and find its way to GEM module, I think A little more verification and will be ready to bring in the glass man for a reseal.
  #34
Old 06-21-2012, 12:00 AM
northsantiam
Had the windsheild replaced, there was very little sealant on top left of windshield from factory. Glass guy said it was one of the worst he had seen from factory. Feel confident about fix.
  #35
Old 06-01-2014, 10:14 PM
skipper89's Avatar
skipper89
skipper89 is offline
vss help
Hay any luck with your excursion im having the same problem with my speado mph not working abs light on od light flashing but runs fine just changed the vss and nothing happen oh I have a 2003 excursion 5.4 v8
  #36
Old 06-02-2014, 06:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
If the new VSS didn't fix it the problem is probably in the wiring to the VSS.
TuggyBoat
19
05-25-2018 06:51 PM
LindenBruce
11-07-2016 11:22 PM
slimfitz
05-16-2016 05:25 AM
brian42
15
08-18-2015 02:46 PM
Archimandrite
08-15-2012 08:56 AM
Quick Reply: Help - VSS, Speedometer
