Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- Drive Shaft Reviews
Reviews and comparisons of top products
Non replaceable U joints on front driveshaft?
2004 F250 4x4
Terrible clicking & grinding/grouling noise when in 4wd during our last storm.
Determined front driveshaft U joints are junk. 150k miles no big deal right?
WRONG? Non serviceable joints!!!
Shaft needs to be changed or cut off factory one and weld on new serviceable joints!! WTF~!!!!
Ford wants $450 for the front shaft....gulp ugh~~~~~
I bet I have maybe 100 miles total using the truck in 4wd over the course of 7 years and 150k miles! I guess it is true it is better use it once and a while even if you don't need it.
Something doesn't sound right. I just replaced all the U-joints and the bearing in the double carden joint on my Front drive shaft a little over a month ago with no problems. Only way you would need a new end on the drive shaft is if the stud on the drive shaft end for the carden joint was bad. This is assuming the 2004's are similar to the 2001's.
I see all sorts of parts shown on Rock Auto for front driveshaft u-joints for our trucks.
JEV -- could you dig up any part numbers for JoeDirt68?
Napa part number PUJ 617 was the kit I used. Two different ones are listed so you have to check to see what kind you need.
The dust seal I found at quad4x4 online. Their p/n is QU40704. That was the only part I couldn't find locally. All other parts were easy to find at any of my local autoparts stores.
JEV
JEV
Some shops don't want to mess with replacing u-joints. Better profit margin for them by replacing the entire front drive shaft. The Cardan joint failed on my '02 F350. A new d/s from Ford was some ridiculous amount of $s. I had mine rebuilt. Any decent driveshaft shop can rebuild and/or replace the joints.
BTW, if the driveline shop doesn't do balancing, run the other direction.
DanielT28
18
06-11-2016 02:52 PM
1984F2506.9
12-04-2014 11:32 PM
drunkenrich
09-06-2010 04:37 PM
petepetersen
08-09-2009 05:35 PM
