Jag front clip with a flathead
Has any one swap a jag front end in f1 51 with a flat head? I know that you can get a power steering pump to mount on the fan pulley. What about the pan might be a problem with clearance? Any thoughts on this trying to make a plan on this build. i have a jag front and rear but may use on another project.Thanks George
I am going to go out on a limb and say that I think that the Jag IFS will fit with the flathead. Take a look at the pix in 48steel's galllery and think about how the flathead sits in the engine bay. Those of us installing later engines typically remove the triangular front motor mounts however they sit above the Jag. I can't remember exactly how the flathead exhaust manifolds are configured (I am more familiar with the 32-40 manifolds) but there should be a workable stock flathead ford manifold.
barrnone51
54
03-26-2017 12:31 PM
Dgrant51
01-02-2015 05:14 PM
barnfind 51
10-09-2012 11:14 PM
barnfind 51
05-24-2011 10:29 PM
