'52 F-1 column shift question
Old 12-26-2010, 04:22 PM
51f1truck's Avatar
51f1truck
51f1truck is offline
My father and I are having a disagreement and need some wisdom...
We have the stock 3 speed transmission with the column shift ("three on the tree"). On the actual lever that you shift, it has a bend in it just as it enters the column. Which way is the bend suppose to face? Does the shift lever bend towards the steering wheel or away from it?
Right now we have it bending towards the steering wheel but it does seem that the small end ball does come close to the steering wheel in first gear and fat fingers turning the steering wheel can get caught between the wheel and the end of the shifter.
Thanks for any input,
Fred
Old 12-26-2010, 08:07 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Just checked on my 52 and the bend is away from the steering wheel.
Take a look at the picture. You can see the bend. I can also check my 51, but that won't be until tomorrow or in the next few days.
Old 12-26-2010, 11:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Mine bends towards the wheel.... but it looks just like yours, Panelman. The bend in the shifter itself brings it back towards the wheel, but in neutral, the shifter as a whole is pointing towards the dash, being spring-loaded that way.
Old 12-26-2010, 11:15 PM
51PanelMan's Avatar
51PanelMan
Hmmm... intresting. Mine was probably "worked on" by the prior owner. I'll have to check the 51. I know that it hasn't been touched as the truck is all original. I also have another steering column with the shifter in my parts pile. I'll check it as well if I can get to it.
Old 12-27-2010, 11:17 AM
firstrider's Avatar
firstrider
firstrider is offline
Just checked the column on the stock truck . The bend is towards the steering wheel .This column is unmolested so think it would be safe to say this is correct .
Old 12-27-2010, 06:42 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
HILLBILLY BOB is offline
Old 12-27-2010, 07:14 PM
51PanelMan's Avatar
51PanelMan
Now that I'm re-reading this post, the shift lever in my 52 is bending towards the steering wheel. I think I misunderstood the original question.
Old 12-27-2010, 08:28 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I wondered, because mine looks just like the pic you posted! I'm curious about the screw used for a pivot, tho; how well does it work?
Old 12-27-2010, 08:56 PM
51PanelMan's Avatar
51PanelMan
I thought that the original post was referring to the bend itself in the metal.
It's not a screw. It's a bolt with a small dome top. There's a nut with a lock washer on the other end.
Old 12-27-2010, 09:26 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
I just want to brag for a minute.... with FACTS.
Old 12-29-2010, 11:58 AM
hylkman56's Avatar
hylkman56
hylkman56 is offline
The "facts" confirm that mine is mounted correctly. Very helpful. Thanks, Havi.
Old 12-29-2010, 12:21 PM
51f1truck's Avatar
51f1truck
Team:
Thanks for all of the info! Very helpful. Looks like we have the shift lever installed correctly.
I guess I will have to tell my Dad either to work on "thinner" fingers or to try a different technique while turning the steering wheel while in first gear!
Best to you all in 2011...
Fred
Old 12-29-2010, 01:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It could be that your linkage is worn at the bottom of the column, or the ball on the end of the lever. Mine doesn't really get that close to the wheel.
Old 06-30-2014, 10:58 AM
sssingo's Avatar
sssingo
sssingo is offline
Sorry. don't want to sabotage your thread but need similar help with my stock 3sp column shifter. I was going to get some rebuild parts but prior to dismantling any further I wanted to know the techniques or whether any special tools might be needed to refit them.
The parts are the bushing at the base of the actual column shift lever. Seems to be held in place by a pin. Does this drill out etc etc??
ALSO.
The bushings on the shift linkages that have rubbers encased in brass washers. When refitted, what holds them in place. how do you refit?
Any help would be greatly received as it is finally sunny here in England and I want to get it all rebuilt and cruise :-)))
fordsforever2015
11-12-2021 11:35 PM
Jersey devil
12-10-2016 12:22 PM
grantkat
09-08-2015 02:48 PM
PapaMatt
03-19-2015 07:17 PM
Thomas Hutchins
1997 - 2003 F150
08-25-2014 09:49 PM
Quick Reply: '52 F-1 column shift question
