96' F-250 exhaust?
96' F-250 exhaust?
it's a 96' F-250 PSD 4x4 Extended cab short bed....My tailpipe is broke just before the axle. I've been thinking of going up to around the rear of the cab and cutting it, putting a 45 degree angle in it with straight pipe running to just in front of the rear wheel. Then getting a nice Slash cut tip for on it......Anyone have pics of this or see any issues? Thanks a bunch
the second pic is what im looking to do. I don't mind a dirty wheel....I've considered upgrading the downpipe but wasn't sure if I was up to doing it. I read it can be a pain to fit in there. How much would a decent downpipe be? Im not looking for anything expensive. The truck is currently all straightpipe. My only plans for the truck is maybe a downpipe and most likely a 3 or 4 position tuner........I wanna keep it simple, I have a 96' Camaro and I'm well aware of how addicting modding gets
I have the Diamond Eye 3" downpipe, it's a aluminized, 2 piece, pretty easy to install. Less than $100. Just search for posts on here about installing it, there are lots of good hints. You'll need a good sawzall with extra blades and something to bend the firewall seam a little to help make room for the new pipe.
That along with a 6637 intake and a 4" exhaust helps these engines breathe a LOT better.
Intake, exhaust, and gauges (EGT, trans temp, and boost) are the best beginning mods. After that you can get into chips and bigger injectors, etc.
on
It all custom made. Had to come up with an exhaust for when I have my topper on. At the time I didn't have a tail pipe and I didn't want just the standard 45 angle pipe. Gonna be going with a tail pipe some time so my side pipe will be for sale!
MMmmm....Keep me in mind, when you decided about the exhaust...cause I am going to put a topper on my truck...
