Writing a New FAQ for 87-96, help and suggestions please?
#31
#32
There should be a line at the top that tells people how to use the search feature. I think most people don't even know about it. I find that the search feature is great, but I don't always find what I'm looking for. Even if there are past threads on the same subject, it doesn't always cover the exact same issue.
#35
#37
I see everyones point...I really do...
I see the point of a FAQ, for what it is...Quickly and easily seeing SIMPLE stuff...Trann ID, etc...
I see Subfords' point....The forum needs hits to keep sponsors...But due to amazingly consistent string of totally ignorant people.....I don't think ONE guy actually using the thing, won't make up for the 100 that don't...
And I see the fact that people will eff stuff up....Then blame it on someone else....Yep..Happens all the time....Still will be blamed....So oh well....
As for suggestions-
-Bleeding the brakes-Most don't know about the RABS haaving an extra point to bleed, which can cause the brakes to not function correctly...
-Swapping steering wheels out...I found out that by using a 1991 crown victoria steering column, Grant wheels uses a different part number for the adpater kit, and is $25, instead of $89.99....Just food for thought....And its a 100% bolt in deal...Literally..
-A good list of sites recommended (Beyond our awesome sponsors of course)....A few that comes to mind is www.LMCTruck.com, www.Partsgeek.com....Among a few others....
-Tire sizes, and what speedometer gear is needed when swapping to larger tires. ALSO, how to recalibrate the PSOM for larger tires, so people don't swap to a larger size, then get all pissy because they're viewing bad info as true, and getting BAD MPG readings, odometer being off, etc...
-Charging/Alternator issue help....How to troubleshoot, and narrow it down GREATLY, if no obvious "Well heck, right there's the issue" is found...
As for suggestions-
Big-Sarge
6.7L Power Stroke Diesel
47
01-17-2024 10:32 PM
Y2KW57
79
02-12-2015 11:47 PM
ManfredVonRichtofen
1978 - 1996 Big Bronco
04-14-2014 09:42 PM
