Iowa Chapter Join Chapter, Leader:
393 stroker
Old 03-22-2011, 09:57 AM
tamndavereid's Avatar
tamndavereid
tamndavereid is offline
393 stroker
Okay this is what i got; Eagle 393 stroker kit, h beam rods, hyper pistons and rpm air gap intake, oh and 89 truck heads may have gt 40 if i need to, anyway this engine is going to be used in a marine application in a very heavy boat the problem is I dont know what kind of cam to use. Any help would be appreciated! Also will I have clearence issues with piston skirt to crank issues?
Old 03-23-2011, 06:41 AM
fellro86's Avatar
fellro86
fellro86 is offline
I would guess that you need a cam that gives torque early, like an rv/towing cam. I doubt you will have any piston clearance issues if you got the pistons that are correct for the crank.
Oh, and welcome to the Iowa Chapter!
Old 03-23-2011, 09:47 AM
tamndavereid
393 stroker
Thank you, and I did a little more research and decided to go with Lunati's 61002 cam. I think its really going to work well for my application and the price wasnt bad. I got the cam and lifters for a little over 210.00 bucs. I'll keep you guys posted on the build. I have to take my Eagle rotating assembly to get balanced today and that also is going to set me back a easy 200.00!
393STROKER
09-01-2011 01:08 PM
Gibby55
05-24-2011 03:41 PM
wvroughneck
01-03-2011 02:19 PM
kellar
18
11-09-2007 07:40 PM
smallblock351w
02-28-2007 06:44 PM
Quick Reply: 393 stroker
