My jeep has a short a cracked leaf three out of four lift springs a rusted through frame rusted off body mounts body panels about to fall off no brakes the cab try's to fill with smoke at highway speeds and one axle shaft longer semi floating the other not one axle shaft 1/2 inch longer than the other it is also my daily driver
I forgot it has a railroad spike for a key makes no oil pressure when idling and the 1st reverse synchros are shot
I have an update on my jeep I had three more leaf springs fall off but only the halves in front of the rear axle I now have a 4x4 for suspension and on an unrelated note I popped one of the front tires
