Transmission for 1965 F100
What about the newer 390 engines. Do they have any 4 or 5 speed transmissions you could bolt up with out much modification. A friend of mine owns a machine shop and about 4 years ago someone dropped off a 390 FE engine to him to be rebuilt the guy never came back for the engine and he said he would give it to me if I wanted it.
As mentioned in a prior post, an adaptor will run you $800 to adapt a Ford AOD trans or a GM 700R.
So....how much you want to spend? A 302/AOD swap might be cheaper than adapting an OD to your FE.
What I am going to do is drop in a Gear Vendors O/D unit because I simply do not want to go with any other engine and want to keep my CJ Automatic.
Pricey maybe but you would not be able to hurt it.
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
just a thought that knowone else has mentioned
Either that or he could go to a built AOD.
I had a T5 in my 96 ranger and as long as you drove like a grandma it was ok. Guy I sold it to blew the trans 3 times before finally replacing it. They were good for what 295 lb ft tq?
The mustang T5's are a very weak trans. He has a Auto and wants to stick with an Auto. At least thats what his post says...
Depending on what engine you had the 5 speed manual in the rangers were from Mazda. They also had a hydraulic clutch....the T-5 has never had a hydraulic clutch.
I have also raced T-5s in my mustangs for years! and yes while I have jacked up 2nd and 3rd gear before, they have never totally blown up on me! Even in my turbocharged mustang.
...I also didnt notice that the OP had a auto.
And yes "originally" it had the Mazda box in it.
Garbz
