Transmission for 1965 F100
Old 12-18-2010, 03:57 AM
sloisell's Avatar
sloisell
sloisell is offline
I have a 1965 F100 352 FE engine with a three speed automatic transmission in it. I would like to change it to a 5 speed auto Transmission. Does anyone know what type of transmission would be best for this model truck?
Old 12-18-2010, 07:06 AM
jowilker's Avatar
jowilker
jowilker is offline
None fit that engine, you will need an adapter (about $800.00) plus the tranny, could be a couple grand.
Is something like that in your budget?
John
Old 12-18-2010, 08:28 AM
SixtySix Ford's Avatar
SixtySix Ford
SixtySix Ford is offline
If I was you I would swap out that ole 352FE for a newer 302 or 351W with a T-5 or a 5 speed out of a F-150
Old 12-18-2010, 11:03 PM
sloisell's Avatar
sloisell
sloisell is offline
What about the newer 390 engines. Do they have any 4 or 5 speed transmissions you could bolt up with out much modification. A friend of mine owns a machine shop and about 4 years ago someone dropped off a 390 FE engine to him to be rebuilt the guy never came back for the engine and he said he would give it to me if I wanted it.
Old 12-18-2010, 11:46 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,719 Likes on 1,404 Posts
390s and 352s are the same engine family, and the blocks are identical externally, for the most part. As such, what fits a 352 will fit a 390, and what doesn't fit a 352 won't fit a 390.
As mentioned in a prior post, an adaptor will run you $800 to adapt a Ford AOD trans or a GM 700R.
So....how much you want to spend? A 302/AOD swap might be cheaper than adapting an OD to your FE.
Old 12-19-2010, 02:44 AM
Boss9F100's Avatar
Boss9F100
Boss9F100 is offline
What I am going to do is drop in a Gear Vendors O/D unit because I simply do not want to go with any other engine and want to keep my CJ Automatic.
Pricey maybe but you would not be able to hurt it.
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
just a thought that knowone else has mentioned
Old 12-19-2010, 11:13 AM
SixtySix Ford
2800+ is to rich for my blood! I'd rather have a 302 or 351 with a T-5....and yes I know T-5s are for cars but my truck will no longer haul anything but ***!
Old 12-19-2010, 12:24 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Ziegelsteinfaust is offline
A T5 from a 86 and newer mustang with a S10 T5 shifter cone is what works in our trucks supposedly.
Since you already have the stick this is about as bolt in as you got.
Old 12-19-2010, 12:40 PM
Boss9F100's Avatar
Boss9F100
The mustang T5's are a very weak trans. He has a Auto and wants to stick with an Auto. At least thats what his post says...
Either that or he could go to a built AOD.
I had a T5 in my 96 ranger and as long as you drove like a grandma it was ok. Guy I sold it to blew the trans 3 times before finally replacing it. They were good for what 295 lb ft tq?
Old 12-19-2010, 05:54 PM
sloisell's Avatar
sloisell
sloisell is offline
I want to stay with the big block. And I don't want to put a car transmission in it I guess I am going with the adapter jowilker mentioned. Thanks for al the replys. I love this site. There is a lot of good information and experience here.
Old 12-20-2010, 05:08 AM
jowilker's Avatar
jowilker
jowilker is offline
You can change out your rear end ratio for a lot less if you are trying to pick up a few mpgs.
John
Old 12-20-2010, 07:40 AM
SixtySix Ford
Depending on what engine you had the 5 speed manual in the rangers were from Mazda. They also had a hydraulic clutch....the T-5 has never had a hydraulic clutch.
I have also raced T-5s in my mustangs for years! and yes while I have jacked up 2nd and 3rd gear before, they have never totally blown up on me! Even in my turbocharged mustang.
...I also didnt notice that the OP had a auto.
Old 12-20-2010, 03:23 PM
Boss9F100's Avatar
Boss9F100
My 96 Ranger had a Hydraulic clutch and a T-5. It also had a SuperCharged 5.0 that I installed when the truck was literally BRAND NEW! Looked factory too.
And yes "originally" it had the Mazda box in it.
Old 12-20-2010, 03:26 PM
Boss9F100's Avatar
Boss9F100
a couple pics of said Ranger...
It was a real S L E E P E R !
Old 12-20-2010, 05:29 PM
garbz2's Avatar
garbz2
garbz2 is offline
Speedway sells a new bell housing to fit the FE to accept T45, T10s or TKO 500/600 transmissions.
Garbz
Quick Reply: Transmission for 1965 F100
