where to find pneumatic couplers
Old 06-28-2010, 08:36 PM
motopsyko32's Avatar
motopsyko32
motopsyko32 is offline
I am looking for pneumatic couplers like these for a 1/2 inch air hose (for a train horn).
Where can i find these (preferably locally)?
Old 06-29-2010, 05:28 PM
ReAX's Avatar
ReAX
ReAX is offline
I haven't had much luck find those locally. A couple of ideas would be high end computer stores, those fittings are used in water cooling processors. Maybe aquarium stores.
If you get in desperate need, you can use brass ferrule fittings. Ace hardware, lowes, home depot should have something that will work for you. You might look there anyway, say in the irrigation section.
Old 06-29-2010, 08:27 PM
motopsyko32
Ace and Home Depot only had Shark Bites for copper tubing and pvc tubing. The guy said it would not work for irrigation hoses.
Old 06-30-2010, 02:16 AM
chiahunw's Avatar
chiahunw
chiahunw is offline
Try McMaster-Carr. LINK
Old 08-16-2010, 12:34 AM
Wyowanderer's Avatar
Wyowanderer
Wyowanderer is offline
They are also available a heavy truck part houses; they are used in air brake assemblies and other pneumatic systems.Iget mine locally.
Old 02-11-2011, 08:45 PM
jessie's Avatar
jessie
jessie is offline
McMaster Carr, Grainger, Festo
Old 02-12-2011, 09:26 AM
rotun's Avatar
rotun
rotun is offline
Reads ***** rules!
Truck parts place, like stated above, should have them for d.o.t. airbrake systems. Running d.o.t. tubing is a good idea as it is rated for service brakes at a wide range of temps.
Old 02-23-2011, 05:34 PM
Zmann's Avatar
Zmann
Zmann is offline
think about PEX fittings ? I don't know if they make what you pictured in 1/2 inch ?
but pex does and it has all kinds of fittings
Old 03-01-2011, 03:11 AM
Roadfind's Avatar
Roadfind
Roadfind is offline
Fittings
Any truck shop/stop , and any Napa store . If you have a air ride supplier dealer in your area . Pretty commen air fitting .
Old 03-01-2011, 08:16 AM
Zmann's Avatar
Zmann
Zmann is offline
He's looking for 1/2 id those aren't common IMHO
Old 03-01-2011, 11:37 AM
Roadfind's Avatar
Roadfind
Roadfind is offline
Fittings
Half inch air line is a common size , I have it in 1/8" - 1" line . They make air line in rubber and hard line that is made from PVC Synflex DOT approved line . The fittings are made in brass and plastic . I like to use brass over the push-pull plastic design . Most good auto parts supply houses carry have most sizes in stock .
Old 03-01-2011, 11:55 AM
Zmann's Avatar
Zmann
Zmann is offline
Good to know
Thanks
I have not seen the larger stuff
Old 03-01-2011, 07:12 PM
motopsyko32
hornblasters.com
Mystic_Cobra
All Other Items for Sale
09-15-2010 09:14 PM
dpellicone
03-17-2008 07:57 AM
MisterCMK
Garage & Workshop
23
05-07-2007 07:57 PM
GeneStoner
Garage & Workshop
28
06-27-2005 08:27 PM
zimman20
Garage & Workshop
24
01-12-2003 05:18 PM
Quick Reply: where to find pneumatic couplers
