'05 f250 6.0 no oil flow/pressure
Thanks steelhead2... like I keep saying...any input is welcome.
so the following comes to mind
Can anyone actually explain to me why... if the high pressure oil is leaking...I would not have low pressure oil.
Is it correct that the HPOP is resevoir fed by the low pressure after it goes through the filter?
I should have low pressure if this is the case. I could see the resevoir running empty, the LPOP not keeping up, if there was a big HPOP leak.
The only way I may not make pressure with LPOP is if it was directly ported to the HPOP. My problem remains...no LPOP flow or pressure
Yes npcc partsman, I got the entire front engine cover.
upper oil pan to bedplate leak at the pickup port. My daughter could of done better on the finish grind on the mating surface on a bench grinder. Very surprised it lasted 5+ yrs. Parallel thickness differences of .008 didn't let the gasket work. Bed plate straight enough. Had .003 milled off the upper pan...got oil now, just gotta put the rest of it back together
dont drop the pan yet
Hello All. My truck died seconds after a warm restart. No previous symptoms. Check Gauges message. After long crank..no idiot gauge pressure. pulled oil filter and cranked... no flow, no oil. pulled LPOP regulator. It all just kinda slid out of the bore like it wasn't stuck. No oil came out with it. Crank with regulator out... not a drop of oil. Pulled LPOP...nothing notable, no grooves, very minor markings actually.
Am I missing something or is my next step to pull the pan? Can the pan clear without jacking the engine?
BTW it does have oil in the pan... just saying.
102,000 miles
Appreciate any help, thanks
102,000 miles
VIDEO INPECTION CAM ( ABOUT A $100 FROM HARBOR FREIGHT) AND TAKE A LOOK.
Hey motor junkie....this is old news. A review of the posts will show you that the upper pan was the problem where it mates the bedplate.
Hell, I'm already beyond that and have studded the heads and put in a Bulletproof egr cooler and oil cooler. It's a good thing I love my daughter cause the factory 6.0 is a POS
Does anyone have an updated link to this video or has it saved off somehere?
I'm trying to get this video as my truck seem to have a similar problem, but it is not there anymore.
Any help greatly appreciated.
old video
speedo9... I copied and pasted the link and went right to it. It is a good video but if you don't have Ford tools, it won't help much.
It'd be better if you had an understanding of the porting of the oil system up from the pan and all the way through.
I could help with that if you tell me what you have done. Once I figured it out, it made much more sense.
Let me know
Let me know
Wow--you got a whole new front engine cover and everything. I'm not sure that you can get the pressure regulator any other way though. I know you can get JUST the gerotor gears for less than $35. I replace (or have replaced) mine everytime I do anything major. Cheap insurance.
One thing about the used front cover though.....it should be very saleable to someone with an 03 or early 04 motor since it has the bigger/upgraded water pump cavity. They are fairly popular.
oil pressure problem also
my 2004 f 250 6.0 has a oil pressure problem about 5000 miles ago I replaced the hpop ,IPR,ICP,EBp because i broke it ,egr delete and oil cooler and now i have no oil pressure on the low oil pressure side put a gauge on the oil filter housing holds about 5lbs cranks for ever befor it will start up but after it starts it will idle smooth,pulled gear pump and pulled cover off on marks or scratches to speek of , need help I am stumped
#28
#29
You need to start your own thread so it will get the attention it deserves. That being said having a trashed LPOP gear and cover is bad news as it usually means it ingested a needle bearing from a failed lifter and the short block will need to be removed to replace the damaged cam shaft.
Haggs21
108
10-15-2020 10:43 AM
bismic
03-18-2017 08:30 PM
Bubba Jones
04-23-2016 11:52 PM
