Ford Heater Valve Warning/Fix (with pics)
#31
#32
#33
#34
Moral of the story: Never, ever, ever trust those spring-type clamps. Installed screw-type on both in and out of heater control valve and it appears to have done the trick.
Thanks rsmarcil for pulling me back from the brink with some old-school back-to-basics. Most times it really is the simplest fix vs. the toughest.
#36
I found this thread while having a similar experience with the "4 Seasons" Heater Valves; They leak through the phillips screws that hold the vacuum servo to the valve ports.
been trying for months to locate a small-but-annoying coolant leak in my 1997 4.0 liter Ford Aerostar until I finally discovered it is a drop-by-drop leak through one of the phillips screws in the Front Heater valve. (my Aerostar has front and rear heaters, the Rear heater valve is not problematic);
I replaced the front heater valve 3 times. YES, THREE TIMES, 2 of the valves were from Autozone, and one from Advance Auto Parts, all three leaked inmediately, although the one from Advance Auto Parts leaked through the vacuum servo diaphragm.
I ordered the oem Motorcraft heater halve through eBay, it has a metal-bodied servo as opposed to the all-plastic "4 Seasons" valves. Seems to me the 4 Seasons valves are not being tested under coolant pressure before being shipped from China. The fact that all these valves are leaking through one of the mounting screws tells me their design is deffective.
suzuki1750
09-07-2008 03:09 PM
