Cummins Conversion VS. Built 7.3
Old 12-07-2010, 05:03 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
Originally Posted by sledheadm7
yea i agree im i do the conversion i dont think i will be going that wild. i still use mine as a daily driver and tow quite often.
If you plan on towing get compounds. They rock!!!
  #32
Old 12-07-2010, 05:05 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
If you think compounds rock, try out a set of triples! haha
  #33
Old 12-07-2010, 05:11 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
I'll one up you. Eventually I want compounds being fed by a procharger
  #34
Old 12-07-2010, 05:16 PM
driximus's Avatar
driximus
driximus is offline
Originally Posted by jkidd_39
Marty is making 800hp plus on pmrs in his pulling truck FYI. Tuning is the key to long life.
Marty sent his PMR's packing quite some time ago his PMR's lasted about a second after he switched from modified stock to 120.
  #35
Old 12-07-2010, 05:20 PM
strokin'_tatsch
How about triples fed by a procharger with a 12 cylinder inline p-pump? LOL
  #36
Old 12-07-2010, 07:16 PM
sledheadm7's Avatar
sledheadm7
sledheadm7 is offline
now we are talking!! lol
  #37
Old 12-07-2010, 07:26 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
Jet engine. Checkmate....
  #38
Old 12-07-2010, 07:34 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
I'm running ~450/1000 on my stock PMR motor. Been running it well over a year now at that level. I have about $5k in mods...
  #39
Old 12-07-2010, 09:38 PM
sledheadm7's Avatar
sledheadm7
^^^ good to know also for the conversion would it be easer to find a dodge donor truck or just find a motor?
  #40
Old 12-07-2010, 09:42 PM
jkidd_39's Avatar
jkidd_39
jkidd_39 is offline
easier to have a donor truck.. Cheaper to buy a pulled engine. Check out cumminsforum.com and compd for engines. There are a few engines on CF right now..
I would recommend R&L carriers if you need to ship something big.. thats what I use alot.
  #41
Old 12-07-2010, 09:47 PM
sledheadm7's Avatar
sledheadm7
yea i have a buddy with a 2003 dodge 3500 that he just wreaked and i might buy it off him.
  #42
Old 12-07-2010, 10:17 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
i would stay with the 7.3 just because i can stand a Cummings. and to me the life of a 7.3 is a lot better than v24, just my 2 cents.
  #43
Old 12-08-2010, 02:55 AM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
correct if we are talking about the same Marty...
quote from his post not long ago
115.76 @ 7400 lbs = ~770 rwhp. Single stage.
Bone stock 97 bottom end. heads never pulled off
his fuel only .
7400 lbs @ 110.54 = ~ 678 rwhp as daily driven for about a year and a half, after spending a full year at ~467-491 dynoed HP on DP Tuning. Oh yeah, after it spent ~100k miles sitting stock in an OBS CCLB Dually. If I recall correctly, I have 15 or so 11 second passes and at least 30, probably closer to 50, 12 second passes.
  #44
Old 12-08-2010, 05:48 AM
driximus's Avatar
driximus
driximus is offline
his fuel only .
Im sure it is I know of only one Marty who is making 11 second passes in a 7.3.
I just wanted the other guy to know that PMR's were not gonna last at 800HP.
This is the little piece of advice Marty told me a few years ago before I blew my PMR's.
"If I were to do it again... I would have pulled my PMR motor, and put aftermarket rods in it. While I was in it, take the money I had saved up and had the motor honed, and a few other things needed for the girdle and mainstud kit, and instead of going for 500 rwhp on fuel - went for 600+ on nitrous."
  #45
Old 12-08-2010, 06:02 AM
ron's power stroke
I know and what I showed is he id doing this on a stock motor other then fuel mods,a little spray,turbo and injectors...if he did the bottom end,a cam and head work he would be even better...as it stand right now he is giving the 1000 HP Cummins a run for there money...its all in the tuning and the single shot sticks now a day's,,there are quite a few guy's makeing very close to 600HP on a stock motor now...
Quick Reply: Cummins Conversion VS. Built 7.3
