Alt ??
Alt ??
Ive got 6.0 w a dying alternator. Ive also got a dead 99 windstar with a freshly rebuilt 130 amp large case altenator. Its putting out 14.2 V in the van.
Here is my question. It will bolt on and plug in to the 6.0 with no modification but won't charge at all. Any ideas as to why?
Edit: Will a regulator for 6.0 fit the alternator out of the Windstar?
Off topic slightly, but when I was pulling my egr valve out, the pry bar I was using sparked on the alt wiring harness...wth??...the insulation was melted on the wires, and they were semi-fused together, with exposed wire showing. Before I fixed it, alt voltage was all over the place, down to 13.2 and up to 14.2, and I have put 3 alternators in it in the last 2 years. Now the voltage is constant at around 14 volts, no big dives anymore. Check your wiring right by the egr valve, probably won't be damaged, but it only takes 10 seconds to look.
I'm thinking that if I installed a 6.0 specific regulator that all would be well.....as I've read that large case and small case 6G use the same regulator.
It is a large case 6G. I had it installed once and it fit perfectly. The plug-in is identical. I only changed the pulley and the battery cable post to orient it in the right direction. The Windstar harness has three wires .
This is the only "regulator/brush holder" assembly offered for the 6G alternator large and small case that I could find: http://store.alternatorparts.com/bru...sembly-31.aspx
I think John Irwin might be on the right track with the wiring/plug issue.
Also meant to say "THANKS" for the information on AC volts at the battery. I was amazed at how many electronics places didn't know or wouldn't admit to knowing about this issue before I found someone to give me the information. Most places check for simple voltage and not current output and call it good. I wonder if this is the reason some people have alternators that "live" for a long time but have constant battery and/or charging issues. It's also the only reason I knew about the 6G alternators being the same--LOL.
