460 swap problems
Old 12-04-2010, 12:00 PM
Restomodifier's Avatar
Restomodifier
Restomodifier is offline
Unhappy 460 swap problems
Ok... First topic here so bear with me. I'm fifteen, I've got limited money, and I've got a 71 F100 4WD that I'm trying to get a 460 in. I've see it done so I know its not impossible. I bought all the mounting brackets and I have everything I need except the "clamshell" part. I've looked in salvage yards, online, LMC, etc. It's getting ridiculous, to say the least. So does anyone know where I can find them? I'd be happy just to get dimensions so I can have some made.
Old 12-04-2010, 08:57 PM
L. Ward's Avatar
L. Ward
L. Ward is offline
"Clamshell"?
Old 12-04-2010, 09:03 PM
L. Ward's Avatar
L. Ward
L. Ward is offline
This should give you what you need to drop a 460 into a F100 4wd that originally had a 360-390 in it.
L&L Products
040495
Mounts W/ Stands Early 4WD
1967-76 360/390 Engine Swapping to 429/460 Engine 4WD Only
Mounts W/ Stands Early 4WD <table width="100%"><tbody><tr><td align="left" valign="top"> <table border="0" cellpadding="4" cellspacing="4"><tbody><tr><td valign="top"> 040495
</td></tr></tbody></table> </td> <td valign="top">
<table class="sample" width="100%"><form method="post" action="http://www.alphacommerce.com/shop/landlproducts/cartTE.aspx"></form><input name="item" value="Mounts W/ Stands Early 4WD" type="hidden"><input name="Price" value="274.00" type="hidden"><input name="PartNo" value="040495" type="hidden"> <input name="Weight" value="25" type="hidden"> <tbody><tr><td align="center" valign="middle">$274.00</td><td align="center" valign="middle"><input src="http://www.landlproducts.com/images/addtocartsm.jpg" style="font-size: 8pt; font-family: Arial;" value="Cart" type="Image"></td></tr></tbody></table>
Old 12-05-2010, 01:03 PM
fordsrgrt's Avatar
fordsrgrt
fordsrgrt is offline
you must be talking about these,its what i use on my 74 f 250 4x4 Advance Auto Parts: Mount Engine-Transmission by Anchor - Part 2502
Old 12-19-2010, 08:04 PM
Restomodifier
Actually, it's the part that bolts to the block, witch the part you just showed bolts to. But then again I'm going off of other peoples info. I saw a picture of them if I could just find it....
Old 12-19-2010, 11:53 PM
RJP66F100's Avatar
RJP66F100
RJP66F100 is offline
This is the best pic I could find.
May be a salvage yard item.
Old 12-20-2010, 05:59 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
That's just a motor mount.
Why would you want to use an old one?
....or do you mean the adapter that goes on first:
<a href="http://www.flickr.com/photos/24183730@N03/2341124942/" title="IMG_1855 by Jim_Urrata, on Flickr"><img src="http://farm4.static.flickr.com/3166/2341124942_bf0cc3e7c2.jpg" width="500" height="375" alt="IMG_1855" /></a>
Old 12-20-2010, 10:06 AM
RJP66F100's Avatar
RJP66F100
He's talkin about seventies style not eighties. The "clamshell" is the black part on my photo. This is Not a parts store item.
Old 12-20-2010, 05:02 PM
RJP66F100's Avatar
RJP66F100
You might try Bill (Numberdummy) on here. He could tell you if there are any nos Ford ones left over.
Old 12-20-2010, 05:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The bosses on the block aren't any different. What's to keep you from using a later style motor mount?
If it's an engine swap that was never available from the factory then it is certainly not a matter of being concours correct.
RJP66F100,
Can you offer 'restomodifer' the dimensions he needs to fabricate something that will work?
Old 12-20-2010, 05:57 PM
RJP66F100's Avatar
RJP66F100
Originally Posted by ArdWrknTrk
RJP66F100,
Mines in the truck now but I sent Numberdummy a PM. Hopefully he can locate them NOS.
Old 12-20-2010, 06:19 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
There are no factory 4WD engine supports (towers, stands, perches) that can be used on any 1982 or earlier F100/350 4WD w/a 460.
The first year the 460 was available with 4WD (and a manual trans) was in 1983-F350 only.
No 460's were offered for F100/150's after 1979.
To install a 460 in a 4WD will require purchasing a mount kit from L&L or Summit. The 1973/79 F100/350 2WD factory 460 engine mounts (2-D3TZ6038A) and brackets (D3TZ6030A & D3TZ6031A) can be used, but there are no factory engine supports for 460 4WD's.
The D3TZ6030A-right/D3TZ6031A-left brackets bolt to the engine block, the rubber insulators (D3TZ6038A) bolt to these then to the supports.
You will also need the correct oil pump and screen, a reverse sump pan, and the adapter to bolt the pickup tube to the engine.
Econoline & Passenger Car 460 mounting parts will not work on any F100/350.
Old 12-20-2010, 10:06 PM
RJP66F100's Avatar
RJP66F100
Bill, that was error on my part, I assumed that he was going to fab 2wd stands or supports into the 4wd truck and for all I know that may not be practical.
But anyway you have listed what I think he was after to complete his parts collection.
Old 12-20-2010, 10:13 PM
Restomodifier
YES! Thank you, everyone seems to look at me cross-eyed when I try to explain. And the reason I don't go with a newer-style mount is that the brackets I bought won't work any other way.
Sschultz13
09-30-2016 11:15 AM
Sschultz13
09-26-2016 09:25 PM
devbravo
04-18-2016 01:58 PM
peakster
05-09-2015 09:53 AM
Luke76
Engine Swaps
09-02-2012 12:58 PM
Quick Reply: 460 swap problems
