04 FX4 Hum and Whine at speed
Hey everybody, I searched around but i couldnt really find anything just like what im having in the fourm
I have a 2004 F-150 FX4 4x4 with 80k with a 9.75 LS, recently I've had the truck start making a humming sound/vibration (simaliar to the sound/feel you get when crossing onto rumble strips, only not as intense) when at speed anywhere above 20 mph or so, its doing this all of the time. The strange thing about the sound is that is only occurs when I am driving completely straight or to the left, if have the steering wheel just slightly turned to the right of center, the sound and vibration completely goes aways until the wheel returns back to center. also I've started to notice that sometimes (not all the time) at lower speeds when let off of the gas and decellerate i'm gettin a very high pitch whine that sounds like a metal-metal sound but only lasts for a few seconds then goes away.
I cant tell where if the sounds are coming from the front or back and i cant decipher which side it is coming from.
Also, I dont know if it is related but over the summer, probably june or so, i had to drain the fluid from the rear end and replace and add an extra bottle of friction modifier to get rid of the shuddering problem alot of people with 04's have run into.
Anyone else run into this kind of problem? I'm tryin to save some money from the dealership hunt and peck method of solving problems lol
Thanks alot,
Dave
Thanks alot,
Dave
Well, the grinding noise almost sounds like a wheel bearing being you said it changes when you turn the wheel, or possibly a bad IWE actuator (for your 4x4).
The high pitch sounds like ring gear whine, and yes the shudder is a bummer (mine is REALLY bad).
Does the noise get more intense if you turn left hard?
battmanf16
1997-2006 Expedition & Navigator
22
03-11-2020 11:36 PM
EpicCowlick
08-26-2007 08:48 PM
catamount
01-23-2007 03:39 PM
