Manual to Automatic Transmission Conversion
I've never done one, but some things to consider would be, are you going to install an automatic steering column, or use an aftermarket floor shifter, your radiator won't have cooler line provisions, but you could run lines to an external trans cooler, I don't know if the driveshaft length & yoke would work, may need one from an auto truck.
You'll also need to bypass the clutch safety switch, (simple), and decide if you want to change out the pedals, or leave the clutch pedal under there. Make sure you use the correct flexplate(flywheel) for your 4.9, & I think the starter is different for auto trans.
Finding an auto column would be a lot nicer, IMO, because the floor shifter gets in the way if you ever need to squeeze 3 people in there, plus you get the park lock and starter interlock.
BS51993
08-06-2014 10:55 AM
mark89
44
02-25-2014 08:07 PM
broncobilly72
01-19-2004 10:10 PM
460, 49, 86, automatic, conversion, convert, converting, f150, f250, ford, manual, manule, swap, transmission, trucks
