Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 11-21-2010, 05:26 PM
FordCrusherGT's Avatar
FordCrusherGT FordCrusherGT is offline
Garage is empty, add now
FordCrusherGT is starting off with a positive reputation.
Loose shifter - can't get into P or 1
Well, after two the past years and 35,000 miles of doing virtually zero maintenance, my truck has actually required me to do a few things the past few months.
The one that I need help with seems related the steering column. As typical with high-mileage Fords, the shifter seems pretty loose. Mine has gotten to the point where it has enough slop that it won't go into Park or 1 reliably. Sure, the shifter will go into those physical positions and the needle will move, but it's not moving the arm on the transmission. I typically have to put it in neutral to start, and have to hit the foot brake because park isn't engaging in the transmission.
What usually wears out to cause this, and is it something that I can adjust out? I've never taken apart the column on a Ford, and it's been a while since I've done it on, well, about anything else. Any suggestions for what to look at or courses of action?
Overall, this truck has been excellent to me. 144k on it total. I bought it at 90k. Have had to do the pads and rotors twice, needed a new computer and coils when I bought it. Other than that, just tires (which got out of balance recently), and today the exhaust cracked right before the muffler. Easy fix. It actually sounds pretty cool as-is, maybe I'll leave it.
__________________
-Ted
'00 Excursion Limited 4x4 -- 6.8L V10/4R100 (150k miles) eBay headers, HIDs, Bilstein shocks
  #2 (permalink)
Old 11-21-2010, 06:06 PM
gr8scott72 gr8scott72 is online now
gr8scott72 has much to be proud ofgr8scott72 has much to be proud ofgr8scott72 has much to be proud ofgr8scott72 has much to be proud ofgr8scott72 has much to be proud ofgr8scott72 has much to be proud ofgr8scott72 has much to be proud ofgr8scott72 has much to be proud ofgr8scott72 has much to be proud of
There's two small screws and probably one of them is coming loose. They are all the way at the brake pedal end. you don't have to take anything apart to get to them or even see them. If you get under there and have someone move the shifter, you'll spot them quickly.
Oh, if you can't get it into Park, one of those screws is probably sitting on your floor mat.
__________________
Scott
2000 Excursion XLT 4x4 V10 4.30, BTS tranny, 6.0L tranny cooler, Scan Gauge II, 285/75/16 BFG AT KOs, ProComp springs 22210 front and 22415 rear, Rancho RS9000XL shocks, Powerslot slotted rotors w/ Hawk SuperDuty pads up front, Hawk SuperDuty pads on the rear stock rotors, Optima Red Top Battery, 05 headlights, F250 grill (In the 200k club now!)
  #3 (permalink)
Old 11-21-2010, 06:16 PM
Thanks, Scott! When I get up to the shop tomorrow I will take a look.
__________________
-Ted
  #4 (permalink)
Old 11-22-2010, 12:32 PM
Took me about 5 minutes to do, mainly because I had to go ask someone to borrow the tools (not at my house). All repaired. Thanks!
__________________
-Ted
  #5 (permalink)
Old 11-22-2010, 08:30 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Are these the 2 screws on the black piece you need to tighten?
__________________
2002 Excursion XLT V10 2WD 4.30 Limited Slip
Bone stock with restrictive Y-pipe and Michelin AT/2
Front Hitch Reciver, Rear Hellwig Sway Bar 7643
  #6 (permalink)
Old 11-22-2010, 09:40 PM
No, I don't think those are the ones.
__________________
Scott
  #7 (permalink)
Old 11-23-2010, 12:43 AM
jh818's Avatar
Quote:
That black whatcha-ma-call-it with the rod attached is the steering column. Am I close? Should I look further up? I think I may need to remove the fuse panel cover.
__________________
  #8 (permalink)
Old 11-23-2010, 01:09 AM
mark996 mark996 is offline
2003 Ford Excursion
mark996 is gaining momentum as a positive member of FTE.
My shift column is a little loose, drives me absolutely nuts. I'm gonna take a look at this when I get home from work and see if tightening anything down there helps out. I'll post some pics with whatever I tighten, figured if I pic everything, hell one of them has to be right?
__________________
Mark
2003 Excursion XLT 4x4
  #9 (permalink)
Old 11-23-2010, 05:33 AM
locknload223's Avatar
locknload223 locknload223 is offline
2000 Ford Excursion
locknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud oflocknload223 has much to be proud of
Yes it's easiest to remove the lower panel then stick you face under the right side. Look up towards the shifter. You'll see two black screws, wiggle the shifter and look for movement.
If those are tight you may need new shift column bushings or even a new actuator rod.
__________________
Mike, PAA Member #127
2000 Excursion Limited PSD- ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, 6.0 intercooler, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, 6637, 4" MBRP, AIH delete, 4" hanger, Vcodes/F350 blocks, Bilstein 5100s, Airbags, '08 diff cover, Dunlop Rover M/TMaxx 315s, '04 headlights, Auto Enginuity.
http://i19.photobucket.com/albums/b157/locknload223/Excursion/004Medium-4-1-1.jpg
  #10 (permalink)
Old 11-23-2010, 06:10 AM
SGnAZ's Avatar
SGnAZ SGnAZ is offline
SGnAZ has a good reputation on FTE.SGnAZ has a good reputation on FTE.SGnAZ has a good reputation on FTE.
I had the same problem,found one of the bolts you pictured on the floor.Tightened em up and the shifter works just fine now.
BTW,it's a torx head bolt,use a T25 to tighten.
__________________
Steve
2000 F-250 XLT 7.3L 4x4 LB
Tags
03, 1996, 1997, bronco, colim, excursion, expedition, f150, ford, ir, loose, park, shifter, sloppy, tighten
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
