Steering Stabilizer...Whats it do
Old 11-28-2010, 09:59 AM
Deerslayinrenek's Avatar
Deerslayinrenek
Deerslayinrenek is offline
Why do you guys run them, what do the help with? Thanks
Old 11-28-2010, 11:26 AM
Etdesign's Avatar
Etdesign
Etdesign is offline
On a stock truck, not really sure but I have a '94 F150 with an 8 inch suspension lift with a 3 inch body lift. When I took the steering stablilizers off to sand and repaint, the truck wanders all over like crazy to the point you can't drive it.
Old 11-28-2010, 11:29 AM
17Z's Avatar
17Z
17Z is offline
sort of like a shock absorber...helps keep 4 wheel drive steering linkage from behaving really 'twitchy'...
Not such an issue with 2 wheel drive vehicles because they generaly have more toe-in..and steering is fairly stable(Unless worn ball joints or tie rod ends come into play)
4 wheel drives are usually set up with less or no toe-in...and need a stabilizer on the drag link to make them more stable and driveable.
My take on the deal anyhow...
Old 11-28-2010, 12:05 PM
patman247's Avatar
patman247
patman247 is offline
stearing stabilizer does work like a shock absorber, except it doesn't try to push out constantly, it helps to keep big tires where you put them with the steering wheel, it helps tremendously with big tires and wheels and on the highway
Old 11-28-2010, 01:02 PM
oleman's Avatar
oleman
oleman is offline
It basically was once installed to keep the wheels from causing the steering wheel to kick back when making a tight turn or when hitting a rock or other hard object io a trail. High speed off roaders use them so if the front wheels come off and they land turned the steering will not turn and take your arm off.
I once had a 4x4 with solid knuckle front axle. That type of axle had a very small turn turning radius without jamming the steeering u-joints. The steering wheel would beat up the driver on tight circles. The stabalizer helped.
On modern vehicles with POWER STEERING and little or no wheel kickback to the steering wheel, the stabalizer is mostly for show.
Spend that money of something worrth while, like more fuel.
Old 11-28-2010, 08:28 PM
Deerslayinrenek
where heres a question, I have a 96' F-250 4x4 PSD when Im turning and the wheel is locked in either direction it feels like the truck is pushing straight and almost like the front tires are skipping.........It has an open rear end so thats not the problem and 265-16 tires.........Anyone know the problem?, oh and it does it on dirt,stone, and pavement
Old 11-29-2010, 03:27 AM
zombie_killer's Avatar
zombie_killer
zombie_killer is offline
Could be your front tires are way out of alignment and are fighting with each other on the turn.
Old 11-29-2010, 10:32 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I have one on my truck and am only running 31 10.50 tires, but it doesn help. I have a black Monroe one. I like it because its not expensive and looks stock.
fordf11948
04-29-2017 06:49 AM
lefty1953
03-17-2017 09:06 AM
Restlesswildman
05-09-2016 10:56 PM
kailor
1997-2006 Expedition & Navigator
01-16-2007 06:20 AM
87carbed
07-26-2006 05:06 AM
Quick Reply: Steering Stabilizer...Whats it do
