Idler Pully ?
Idler Pully ?
Ok so I kept having a squeek when I started my truck so I started it up and started spraying wd-40 into the pilots and the one next to the AC unit if looking at the truck on the right side of it was the culprit it has a little play in it but not much so can I buy just bearings and put them in or should I get the pulley? The pulley looks good no grooves and the belt doesn't move on it. Also any idea the cost either way?
The three idler pulleys are between $10 and $30 depending on the brand.
I replaced all three trying to get rid of the squeek and it turned out to be the belt that was making all of the noise.
WD40 will make a good bearing go bad real quick. The best way to check them is to take off the belt and spin them by hand.
Personally I would just buy the whole pulley instead of replacing the bearing, they are fairly inexpensive.
Received 5,160 Likes
on
Well I know for sure it's that idler pulley and not the belt slipping the belt is only a year old from when my water pump went out and stupid me should of replaced the upper radiator hose to the duel alt type so if I need to replace the belt I don't have to pull the hose. Are all of the idler pulleys the same size?
on
Good luck, all three pulleys can be changed in 10 mins or so. I hope it fixes your problem. I hate squeeks.
on
my P/S pump is whining a little bit, so I'm going to replace it and just because I'm there the idler and the tensioner at the same time. since my kid drives the truck all the time I rather replace them now before something happens...
maintenance people, its all about maintenance...
now taking orders no waiting. lol
