Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
2005 Freestyle coolant leak.
Old 11-15-2010, 10:50 AM
jdman1's Avatar
jdman1
jdman1 is offline
I was changing my oil last night and notice coolant dripping. As I stand looking at the motor it was coming from the right side(drivers). It looks like the water pump(think thats what it is) between the motor and air cleaner. There is a round 1 1/2 inch connection to the motor and seems to be leaking there. First off, is that what this is if not what is it called? Then, is it a big deal to replace this myself?
Thanks!
Old 11-16-2010, 07:50 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Yep thats the water pump. Its not hard to change there are 3 bolts that hold it to the head, one bolt that holds the impeller to the cam, and 2 bolts (I think) that hold the pipe to the pump. Then there is a hose at the bottom.
Old 01-04-2011, 02:25 PM
jdman1's Avatar
jdman1
jdman1 is offline
So sounds like not a big deal to replace. Is there just a gasket/seal that the pump connects to the head? The bolds that holds the pump on just pushes pressure onto the seal on the head?
thanks!
Ty_Deschaine
03-18-2017 05:31 PM
ehask71
11-18-2016 08:40 AM
hugger2000
02-08-2016 09:51 AM
killergsxr1
12-31-2015 09:49 AM
redfish67
1997 - 2003 F150
05-25-2011 10:17 PM
Quick Reply: 2005 Freestyle coolant leak.
