Help with vibration problem...
I'd get ahold of the leveling kit manufacturer. They can probably recommend a shim, or other fix for the vibration. BTW, your rim width is a bit narrow for those tires, especially the 325's you 1st put on. I don't recall any 285/65 18" tires as stock. Stock tire size for your truck w/ 18" rims should be LT275/70R 18E. Either way, you probably didn't change total dia much more than an inch (bigger). The more I think about it, the more I'm thinking it's a tire issue. I would find something else you like in a tire (through the tire center you're using), then try'em.
battmanf16
1997-2006 Expedition & Navigator
22
03-11-2020 11:36 PM
wogdiml
1999 to 2016 Super Duty
29
11-19-2010 03:52 PM
