Pennsylvania Chapter Join Chapter, Leader: liftnw8z
Ign control module
Old 11-02-2010, 08:19 AM
BEAST428's Avatar
BEAST428
BEAST428 is offline
Ign control module
My 1979 Bronco developed a major miss this weekend. After doing some testing I figured it was coming from cyls 1 and 6, direct oposites on the distributor. It ran perfectly before this. It has a brand new 460 with edelbrock performer carb and intake. Motorcraft 8.5mm wires and autolite double platinum plugs. My question is, the ignition module (original) is melting that amber colored goo from the back. I am thinking my problem is coming from this. Any suggestions.
Old 11-02-2010, 04:02 PM
fire240's Avatar
fire240
fire240 is offline
could very well be the module going south.
Old 11-07-2010, 07:02 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
usually when they start to ozze the goop out the back, they have overheated, and soon will let you stranded in the intersection. replace it, and the miss should go away
Old 11-11-2010, 08:27 PM
BEAST428's Avatar
BEAST428
BEAST428 is offline
I replaced the module, reset the timing and finally found out it was just a hunk of crap in the carb. DUH
Sw1tchfoot
27
12-11-2012 09:21 PM
78pace
02-01-2012 11:31 AM
pscrow86
1999 to 2016 Super Duty
11-24-2009 08:19 AM
firefytr29wfd
1997 - 2003 F150
06-23-2005 12:29 AM
danlee
05-19-2005 07:20 AM
Quick Reply: Ign control module
