1979 ford f150 wont start need help!!
ok so i have a 1979 ford f150 that i have bought about a month ago and that i cant start. it worked fine on the way home but then it just wouldnt budge to startit is a 400 ive already replaced the pick up coil, distributor cap, spark plug wires and igntition coil... i am so confused it has spark and fuel but it wont start? would apreciate your help thanks!
Could be the plugs. (Why would you change the wires/cap/rotor but not plugs anyway?)
Could be the carburetor.
Could be a plugged fuel filter.
Could be a bad fuel pump.
Could be any combination thereof.
Could be any number of other things, too with the little information we're going on here, but most likely the carb is in need of tuning/rebuilding, given that it ran when you drove it home and you're just not able to start it. I'd start there, though it wouldn't hurt to throw new plugs in it too.
so i have a 78 f250 and i just figured out the problem, make sure the rotor inside the distributer didnt flip on you, that was the problem with mine, i replaced the plugs, i knew i was getting fuel and everything, it would turn over but wouldnt fire off, i replaced alot of ****, but i looked and the rotor was trying to fire off on plug 4 instead of 1, so that might be something to look into.
FuzzyF150
07-01-2016 11:15 AM
1979fordf150rebel
01-25-2012 11:03 AM
1979 F-150 4x4
11-16-2011 07:12 PM
