2001 5.4 ltr coolant leak
Old 11-11-2010, 08:58 AM
wkeller2010's Avatar
wkeller2010
wkeller2010 is offline
I have a 2001 expedition that has developed a coolant leak. Leak appears to be on top of the engine, in front on passenger side. The area around the front fuel injector (on passenger side) is wet and water is running down and sitting on top of engine (under intake manifold). My first thought was that the heater hose extending vertically from the block hose fitting. I have found no evidence of a leak in the hose but it appears fitting on block may be the source. It has three bolts holding it onto the block. One from the top and two coming up from the bottom. Two of the three area accessible. Have no idea how to get to the upside down bolt nestled between hose fitting, block and valve cover.
It's been a slow leak so far but I know that's not going to last. Runs fine but steams from water on block at stops and when parked.
Any help is appreciated.
Old 07-31-2014, 09:34 PM
fdeven060207's Avatar
fdeven060207
fdeven060207 is offline
Help!!!
I am currently having the same exact problem. Any help or recommendations would be greatly appreciated.
Old 08-01-2014, 08:26 AM
JWA's Avatar
JWA
JWA is offline
Received 1,394 Likes on 1,103 Posts
You guys can post this same question in the Modular Motors forums---its more engine related than climate control.
There is a tube running under the intake leading from back of the water pump---that might be the leak source.
diesel 04 X
03-27-2024 03:12 PM
Stewart_H
508
09-15-2023 04:57 PM
wakeupluis
01-01-2017 06:01 AM
Supercab
15
10-25-2016 02:38 PM
Neckfitter
10-11-2000 11:44 AM
Quick Reply: 2001 5.4 ltr coolant leak
