Backlight on Bully Dog Outlook Monitor
oops.. sorry it took me so long to get to this.. ive not been on the net much lately.
I sent you a PM
But its usually something you have to send in to get fixed. im sure if you were good with electronics tho you could swap the LED out and get it to work again tho.
the reason i say send it in is because sometimes we find something else wrong with the monitor and repair or replace from that point.
I sent you a PM
I sent you a PM
I sent you a PM
The LED replacement is not terribly hard, just finisky, and when you pull the board you have to be careful you dont break one of those 20 wires soldered to the baord. Thats what happened to me on my second LED attempt and I thought I ruined the board, turns out two wires had broke off. Luckily with my wife holding the board flat I was able to resolder them. Now all I have to do is get the nerve up to get another LED and try again. If you pick some up get 2 or 3. Its finicky. Also a small roll of tinfoil with sticky 1 side to replace what you peel off to get to the LED is also required. Tip, use the metal furnace dcuk tape (not ordinary duck tape).
Starry Night
1997-2006 Expedition & Navigator
28
04-12-2020 01:06 PM
gwshaw
1983 - 2012 Ranger & B-Series
12-10-2016 09:14 PM
xRotorHead
09-16-2016 06:04 AM
