Head gaskets and Studs, To resurface or not to resurface heads
During some routine maintenance i have sent the antifreeze and oil to blackstone for reports and show no fuel in oil and no containments in antifreeze, heads and gaskets seem to be great, but before i install turner i am putting in new gaskets and studs
During some routine maintenance i have sent the antifreeze and oil to blackstone for reports and show no fuel in oil and no containments in antifreeze, heads and gaskets seem to be great, but before i install turner i am putting in new gaskets and studs.fficeffice" /><O></O>
Cheezit, are there any indicators concerning how bad head gaskets leak that gives you any forewarning as to out of spec head warpage? Have you seen any patterns that would give someone any idea what to expect before they pull it apart? I'm only seeing evidence of head gasket leakage under heavy load and was trying to calculate for a worst case senario befor tearing into the engine. What's the cost of a new set of heads for the 6.0?
<TABLE style="WIDTH: 339pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=452 x:str><COLGROUP><COL style="WIDTH: 339pt; mso-width-source: userset; mso-width-alt: 15968" width=452><TBODY><TR style="HEIGHT: 25.85pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 339pt; HEIGHT: 25.85pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=34 width=452>New Cylinder Head Check Procedure Video</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 410pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=546 x:str><COLGROUP><COL style="WIDTH: 410pt; mso-width-source: userset; mso-width-alt: 19296" width=546><TBODY><TR style="HEIGHT: 25.85pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 410pt; HEIGHT: 25.85pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=34 width=546 align=left>New Cylinder Head Check Procedure Video
Warped heads are a rare occurrence - at 4:28</TD></TR></TBODY></TABLE>
Checked heads saturday night and all checked and cleaned well, i actually used the .002" feeler guage to start and none of the 13 spots were loose whjile using it. Have heads and studs in, motor was 100% as of last night, installing cab tonight, Prob would have had it done over the weekend, but during assembly saturday i found an oversite, i forgot to order rubber gasket between head and rocker box, so truck had to sit and wait till monday.
#29
I own a small diesel shop and work soley on the ford diesel lineup. When heads come off there sent to a reputable machinist. If they are more than .008 out they get replaced. .008 is pushin it tho. from expeirence,heads shoulds always be milled or replaced when removed. No exceptions with me. Btw....ford says .004
#30
