Hot Shots Secret Saved Me Some Money
not on the forum. just people i know who have 6 liters. obviously they are mis informed.
Received 1,448 Likes
on
There are some good additives out there along with some not so good. Now for the 6.0 injectors that suffer from stiction it doesn't hurt to try an oil additive like Hot Shot or Rev X to see if it solves your problem before investing in a new and expensive set of injectors.
I for one can say Rev X worked on eliminating injector stiction on my truck before I got the new inductive heat flash so I know this oil additive worked for my application. It's expensive and requires continued use and the upgraded flash cost about ~$100 one time expense so thats the long term fix I went with.
OK, I'm curious about something with the SeaFoam. It contains Isopropyl Alcohol, 10-20% by weight.
http://www.seafoamsales.com/componen...oad/view,file/
I thought alcohol in the fuel was a no-no.
Sea Foam has only 6% IPA by volume for moisture control and has been used in diesels for 60 years without any problems.
Jim Davis
Sea Foam Sales Co.
Technical Service Manager
ASE Certified Automotive Technician
on
I'm not saying that it won't work for the 6.0 or that it's bad for the 6.0(I'm not saying that it isn't either), but just because it worked in past diesels doesn't mean that it's going to work that well with regard to the newer ones. Imagine what things worked with past diesels that don't cut the mustard with the 6.0, even when comparing a past diesel like the 7.3 psd versus the 6.0. A lot of differences between the two that make what works with one doesn't work with the other.
HSS WORKED
Well 1000km with HSS in running 5-40 mobile 1 , ok so temps were -8c or 17 deg f no cold start issues any more runs smother idles smother very happy 2006 f350 was worried after reading reviews and how much better rev x is , no smoke on start up better turbo spool just all around better
I put Hot Shots in mine about 2500 miles ago and I have to say that I am impressed. I use 15-40 Rotella in mine and it was acting crazy on cold starts.....usually always a puff of white smoke that smelled like diesel fuel and it would miss and shake when it would start. Now I have started it without plugging it in down to 5*F and it started great. Every now and again it will puff out a little smoke but it starts up and idles smooth. I didnt notice any MPG difference but it was well worth the money to me.
Christof13T
105
08-22-2014 10:12 PM
acreature
11-26-2012 06:07 AM
