99 Ford turn signal/dash signal problem
Hello everyone. Quick question for some ideas. I am having an issue with the drivers side front signal light not working. The dash indicator light ( a left arrow ) also doesn't work but the rear signal and trailer signal lights both work. I have checked fuses, light bulb ( changed it just in case ) and wiggled the turn signal switch with no result. The marker light below it works just fine so I don't think it's a ground issue. Flasher works because the rear light blinks at a normal pace. So I wondered if anyone knew of any issues that occur on these or had any ideas on where to look ? Any feedback would be appreciated. Thanks in advance.
