They say "Heavy Duty"
#31
Ah. Thermodynamics. Bingo. There is a way to squeeze out more efficiency of combustion engines. The hard part is those methods of doing it are so advanced it is cost prohibitive. If regulations change and the advanced technologies are forced on automakers then the cost will settle down after the initial hit. Like DEF - once its mainstream, ie - not "rare", the cost goes down. Ceramics will go a long way towards thermodynamics. I am sure there are other options too.
The compressor wheel that powers over 200 hp engine hides behind US quarter. Thanks to light turbo weight and 200,000 rpm the engine has no noticeable turbo lag.
How small is the latest turbo coming from Ford?
Fact that 200 hp German diesel engine can be lifted by single person, while Ford's equivalent needs a forklift speaks for itself even farther.
Top it with the fact that many German parts in this country are cheaper than coming from Ford.
#32
I already posted a picture that shows 10 years old German technology in turbos for engines.
#33
the 2011 6.7l is 400hp... a LOT of difference.
sam
#34
One thing I have seen in the works is finding ways of making heavy vehicles more fuel efficient by finding wasted motion.
In the example I saw an engineer had figured out how to run the alternator off of the shock absorbers. The up and down motion was more than adequate to spin a turbine hooked to an alternator and keep the batteries charged, even on smooth roads. You WILL see this technology on medium and heavy trucks in the next 5 years or so.
#35
#39
I doubt it's going to be double. If you're only pulling half the train you're only pulling half the freight and by extension half the load. You only need half the equipment and fuel costs will go down as well. Naturally there would be certain fixed costs that wouldn't change (to a point) if you were pulling one car or 10, but it's doubtful costs would double.
tuck1
15
07-10-2010 07:20 AM
48fordcoe
06-22-2010 11:02 AM
