460 Windsor? Sounds unheard of to me. Some people need to be informed
I have a fantastic questions to ask the expert. One day while browsind youtube a came across a video on a 460 stroker fox body mustang.
Someone mentioned that it was a 460 windsor which i am fairly sure it is not since i can only find info up to 429 cu. in. on these motors. So i was telling this person who claims to be his buddy who owns the car and said that it was not a 385 series 460 but definately a 460 windsor.
I will post the video and if you guys check it out maybe if a group of people say that it is not a windsor (that i am fairly sure of) then it may sway him to believe what we are saying or we could get banned form posting on that video which has happened before i can give out my prove.
Here is the vid link.
http://www.youtube.com/watch?v=dQo7BqOahms
I currently own a 92 f250 with a 460 and slowing coming up with ideas and combos to make a 521 stroker combo for roughly 700ft. lbs. I don't care for horsepower as much cause torque has more of a feel. Aftermarket computer or maf conversion will be done as well.
I will try posting in some other sites because this is a 385 series website and not for windsors.
Thanks for your time
World products sells a 460 Windsor crate motor making over 600hp.
It does use an aftermarket Windsor block tho.
World Products - MAN O'WAR 460 Complete Engines
check the deck height. It is 9.5 a 385 series engine is 10.3 a 351w is 9.5
And what about using an all alum windsor block?
My only point was that yes you CAN get a 460 Windsor.
BUT the head choices for a 385 series engine would give you a lot better hp potential.
although size would be an advantage of a 460cid small block. fit in a smaller engine bay (can you say big cubic in mini cooper?)
Im actually doin somethin similar with my stang only Im using a 302 cammer block and building a cobra/mach1 engine. Some people dont realize that if you take a 4.6l(281cid) engine with a stock crank and bore it out to 3.7" that you get 302cid. Anyway I can imagine this very thing being possible
nflfreak43
04-10-2017 12:42 AM
Lead Head
93
11-11-2015 09:48 PM
640 CI Aluminum FORD
Ford vs The Competition
01-11-2012 08:18 AM
Kwikkordead
21
01-18-2011 07:38 AM
maxell3655
10-24-2010 10:25 PM
