Vacuum advance question on a 66
I have a 66 f100 with a 352 and I am trying to replace the vacuum advance module but the problem is all of the part stores that I have tried don't have the right one. The one that came off of my truck has a screw on line (like a brake line) but the one that the part stores have has a tube that the vacuum line would slide up on. Has anyone else run into this problem?
There are two possible vacuum diaphrams, one has a threaded line, one does not, so I need that stamped ID number.
The distributor may have been changed to one from a 1960/64 Passenger Car.
I have one of those types in my spare box. When I redid it I got a Motorcraft DD 190 vacuum unit which comes bare. This is the small can unit seen in the 60's and not the big can from the 70's. I then unscrewed the end from the old unit and moved the insides to the new unit and then screwed on the end piece which takes the threaded line. I have several end pieces in the threaded version and the nipple version to use as I please.
C5AZ12370A .. Vacuum Advance (Motorcraft DD190) / AVAILABLE (!) from Ford.
MSRP: $54.84 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $29.62 / PartsGuyEd = Horizon Ford in Seattle WA
This is what the parts catalog calls for...for a 1965/67 F100/350 352, 1965/66 Galaxie/LTD/Thunderbird 352/390/428.
Prolly fits other applications as well.
xjcamaro89
2004 - 2008 F150
447
01-31-2022 07:35 AM
Ford59galaxie
21
02-12-2016 05:29 PM
86rustbucket
02-17-2004 06:52 AM
