1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
6.0 stutter?
Old 10-20-2010, 10:27 PM
djanzen's Avatar
djanzen
djanzen is offline
6.0 stutter?
Here is my problem 2003 6.0 ps 210000kms, in the last three to four weeks a stutter has started to occur at 2100-2500 rpm about 1/2 to 2/3 throttle, this happens only when cold, not dead cold start and go but run for about five to ten minutes then driven. no smoke when it happens, when it started about a month ago you could barely feel it in the seat of your pants, then it would go away and come back, but today it was very noticeable almost bucking and jerking. when the engine is at full operating temp this all goes away, all the time. the egr has been deleted so I know it is not that.
I am thinking a ficm issues or the injectors, What do the techs think?
Old 10-20-2010, 11:44 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
Funny, I have the same issue really but its hit or miss with mine, can be fully warmed up and do it, get to a red light once it turns green no stutter at all. I know it has something to do with the fuel delivery, but I'm thinking it might be time for a new motor soon.
Old 10-21-2010, 12:56 AM
i eat hybrids's Avatar
i eat hybrids
i eat hybrids is offline
Sounds like yall gotta case of stiction. lol What kinda oil do yall use?
Old 10-21-2010, 06:41 AM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
Post this in the 6.0 section, there are a few VERY knowledgeble techs that hang out there and grasciously offer great help. Also, check out the stickies at the top of the 6.0 page.
Old 10-21-2010, 07:48 PM
djanzen's Avatar
djanzen
djanzen is offline
Originally Posted by 06silvercrew
Post this in the 6.0 section, there are a few VERY knowledgeable techs that hang out there and graciously offer great help. Also, check out the stickies at the top of the 6.0 page.
I posted this in the wrong section last night, about two minutes later in the 6.0 and have had some help from there already. Thank though
Old 10-24-2010, 11:19 PM
FossenRacing's Avatar
FossenRacing
FossenRacing is offline
I had simular symptoms from my 03 f350. It also had a few other problems arise later. Mine was the ICP sensor. its on the back of the block on 03's and was a pain in the butt to change. It usually fails due to a oil leak in the oil filter or turbo oiling system that then soaks the heat wrap around it with hot oil. then the sensor breaks in two.
My truck ran good on initial startup then it would start to spudder a little then it would shudder so hard it would rock the truck. if you drove it at first it was fine but then later if you were going down the highway at 100km/h it would throw you in the seat, squak the tires and belch black smoke. i changed it the next day and now it fine.
Old 10-25-2010, 06:12 PM
djanzen's Avatar
djanzen
djanzen is offline
icp has been changed about a year ago and no oil leaks. the truck drives excellent once it is warmed up this is just a part throttle semi warm problem
Old 10-26-2010, 12:57 AM
i eat hybrids
Whats the ICP sensor?
Old 10-26-2010, 08:58 PM
runmaster's Avatar
runmaster
runmaster is offline
the icp is the injector control pressure sensor. i replaced mine today due to random missing or bucking and it seemed to fix mine 2004 6.0 turbo mine was on the front right valve cover
l0b0
06-27-2017 01:39 PM
Gunt
10-18-2016 07:24 AM
Ctafthorse
06-24-2016 04:31 PM
Beaters
6.4L Power Stroke Diesel
07-21-2013 06:59 PM
shoffroad2
01-03-2011 03:17 PM
Quick Reply: 6.0 stutter?
