good source for lower door seals?
My truck has been missing the lower door seals since I bought it, and likely much longer given the rust I just fixed along the door bottoms.
Does anyone know a good source to get the seals from? Truck is a e99 7.3 sc sb if that makes a difference. The dealer is quoting me $40 per door, so $160 for all 4. Wondering if there is somewhere cheaper to get them from?
Try Parts Guy Ed, site sponsor here www.partsguyed.com
1C3Z28253A24A BODY SIDE DOOR LOWER AND 253A25, WEATHERSTRIP: [SUPERCAB NEW DESIGN L SHAPES - MUST BE MOUNTED ON THE DOOR SO WHEN DOOR IS CLOSED THE L SHAPE CLOSES AND MAKES A V SHAPE, TO MAKE A PROPER SEAL, ALSO PUSH PINS MUST BE INSTALLED ALL THE WAY OR WEATHERSTRIP WILL BE LOOSE. CLIPS INC
on
I need to replace these on my rear doors as well as one front door. They do keep mud out from between the door and the area right under the inner seal. I don't have an actual part number, but if you look at Parts Guy Ed's website (Horizon Ford, just click his links above or do a Google search for 'partsguyed') you'll find them under:
Collision Catalog - (YEAR) - Ford - F-350 SUPER DUTY
body hardware, rear door, door & components, lower wstrip CREW CAB Left (or right obviously)
