Storing your truck
Old 10-17-2010, 11:48 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Mine gets stored from about now until about May 1st. It's also in an unheated garage on concrete. I check the antifreeze level to be sure it has enough, add fuel stabilizer to the tank and disconnect the positive battery post. I do have a cover for it. I put a 2 Amp charge on it overnight when I'm ready to start it next Spring. That it...
Old 10-17-2010, 04:14 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,059 Likes on 804 Posts
There seems to be a couple of different storage routines suggested. I'll throw mine in, nothing too elaborate, have been doing it this way for ten years and haven't had any abnormal problems starting in the spring. I park my trucks in a pole building with a dirt floor and haven't noticed any ill efforts to the underside of the trucks. I dump Stabil in according to instructions and after I have them in their winter resting places I dump oil down the carb goosing the accelerator linkage until I get a good cloud coming out of the exhaust and then leave the engine choke off. Disconnect the batteries, cover and then good by until the Spring. The shed I park them in is at the back of the farm and inaccessible most of winter. I do go down once in a while during the winter to check in and say "Hi", but other than that they're on their own until Spring.
Old 10-18-2010, 07:11 PM
dans 51 f2's Avatar
dans 51 f2
dans 51 f2 is offline
storing your truck
thanks for all the suggestions. i have had the truck since 07. i do most of what has been suggested. i will be working on it this winter. change rear axle to a 3:73 ratio, brakes, new interior, fix some wiring. nothing major. runs good and looks good too.
Old 10-18-2010, 07:21 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Are you running the stock rear axle and changing gears or swapping in a newer one?
jevanof
Michigan Chapter
13
09-19-2013 10:07 AM
just another truck
Michigan Chapter
03-22-2011 11:03 AM
armstrongfordtrucks
Michigan Chapter
02-21-2010 11:46 AM
Michigan Rick
01-18-2010 09:09 AM
weldboy
11-11-2004 05:14 PM
Quick Reply: Storing your truck
