Who uses a drop in bed liner?
Old 10-10-2010, 05:46 PM
Dark Waters's Avatar
Dark Waters
Dark Waters is offline
Brand? Likes-dislikes? Pros/cons?
Thanks.
Old 10-10-2010, 05:49 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
I don't, and I don't recommend them to anyone.
Besides the fact that they allow water to be trapped between the liner and bed, allowing for serious corrosion, there's just no grip to them. Unless you strap down whatever you're hauling it slides all over the place.
Everybody I know that's used one has regretted it.
Old 10-10-2010, 05:57 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I Have a YORK bedliner in my crew cab because it came in it and already wore the paint off so i left it. But it has provisions for 2x6s every 2" so you can section off your load so it does not slide
Bedliners and other truck bed protection products from Auto Trim Design of the Greater Lehigh Valley.
Old 10-10-2010, 06:08 PM
polarismuddman's Avatar
polarismuddman
polarismuddman is offline
Old 10-10-2010, 06:42 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
so strange.
i read often how they "trap water" and rust your bed out.
yet iv never seen it happen lol.
i had a plasic under bed rail type on my old '96 f150 and every couple years id pull it out to wash under it and mostly just to look at the condition of the bed and paint.
every time i lifted it,it was dry as could be.dusty/dirty actually.id hose it down to see paint that looked far nicer than the rest of the truck lmao.
same experience with the ones that go on top of the bed rails.
cool thing about them is you can find them everywhere used for 50-100 bucks.
the easy pulling stuff off like wood and brush is nice.easy to shovel off mulch etc too.
the lack of grip surface i could see being a sucky thing,depending on what you haul.
strap loose items down i guess or they'll slide all over.
i totally killed that bed on the outside(dented to heck,and scratched all over.)but under that liner it looked like the day i bought it lol.you knw how a bed will get all wavy when throwing wood in it over time? not that bed.the outside sure did though.
i wouldn't get to fussy with brand names.find a good used one and start throwing whatever you want in it.
if i recall mine was a pendaliner? -some kind of name like that.it was stamped up on the front in the center.that's why i recall it (was on the truck when i got it.)
im talking daily hauling wood/brush/mulch etc here for a tree service.not just a couple cord per year.
Old 10-10-2010, 09:38 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I just use a rubber bed mat and nothing else. I like it the best. The drop in liners are complete crap and I dont like the spray/roll on type because you will never get it all off if you have to and if they chip or flake, then moisture will get behind it and cause rust. If the inside of the bed looks bad, just get it repainted and get a rubber mat.
Old 10-10-2010, 09:44 PM
jpcnorthwood's Avatar
jpcnorthwood
jpcnorthwood is offline
The drop in liners are good. I had them in both of my other trucks and I have been watching Craigslist for one for my newer truck. I have a rubber bedliner now and I do like how things do not slide around. Maybe I will throw it on top of my drop in when I get that.
Old 10-10-2010, 10:09 PM
truckrider814's Avatar
truckrider814
truckrider814 is offline
I've had a ford bed liner since the truck was new off the lot. and i agree i don't see how it traps water every time i lift mine it's dry no rust just dusty. I love it, yeah crap slides around but If you have crap in the bed shouldn't it be strapped down anyways?? And i like that i can put a piece of old furniture in the bed and not worry about a spray/roll on bed liner scratching it all up. Most liners you don't have to worry about it chipping or fading an having to redo it over again. My .02 always had one always will.
Old 10-10-2010, 10:37 PM
m715's Avatar
m715
m715 is offline
- Rubber bed mats, stops stuff from sliding, cheap, easiest to install (just roll out), but only provides protection for the bottom of the bed
- Bed liners can be cheap, easy to put in, and provide good protection, but wear against paint, trap water=rust in NY anyway and everything slides around. (oil underneath helps prevent rust)
- Roll on bed liners I've had mixed results with, not much protection (generally thin coating), and I haven't been happy with the one i used, i would just paint the bed instead
- Spray in bed liners, friend had Rhino liner sprayed on about 1/4"? thick, full bed and top of bed rails, great traction, tough, and has held up really well to abuse, but most expensive almost $400?
Old 10-10-2010, 10:53 PM
rikard's Avatar
rikard
rikard is offline
All of my drop in liners have protected the bed well without causing rot. I used old truck mud flaps screwed to the bed to keep stuff from sliding.
regards
rikard
Old 10-10-2010, 11:00 PM
ExtrmZ's Avatar
ExtrmZ
ExtrmZ is offline
i had one in my truck, and it rusted on top of the wheel wells, almost all the way through. They are extremely slippery when some snow get in there. i am not a fan at all
Old 10-11-2010, 12:15 AM
86F150302's Avatar
86F150302
86F150302 is offline
Im thinking of either doing a Herculiner or finding a bedrug.
I saw a bedrug on craigslist for $50 a few months back. Still kicking myself for not getting it.
For right now I just have a big rubber mat in it.
Old 10-11-2010, 02:19 AM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
Maybe it depends on the condition of the bed when you install it; maybe they're not installed properly; maybe it depends on your climate- I don't know.
Like I said, everybody I know that's used one has regretted it. My uncle had one in his F150 and trapped water rotted out the wheel wells and random places on the bed. A friend used one and it would trap water right up next to the cab on the passenger side. He never knew it until he noticed water dripping from that corner of the bed. And I've known a couple of other people with the same problems.
I agree w/ Texasguy- I have a rubber bed mat and that's good enough for me.
Old 10-11-2010, 07:06 AM
wickedklown83's Avatar
wickedklown83
wickedklown83 is offline
agreed... i wont say you should or shouldnt... its personal opinion.. but my ipinion on it is i have had one in my 97 ranger as long as i have owned it and under it is dusty as all hell, but rust free... and i EXTREMELY abuse the bed.. also my 89 f250 had a bedliner in it its whole life and under it is pretty well clean... a few minor surface rust spots from the bedliner rubbing
Old 10-11-2010, 08:40 AM
GLR's Avatar
GLR
GLR is offline
Got rid of the bed liner that came with the truck. Tried "rock-it " from SEM do it yourself. Was going to spray it but, too windy so I rolled it in with a 4" roller w/ a 3/4" nap. Looks good but time will tell. I hear from others that on the rubberized coatings the clumps of rubber pull out but, don't know for sure. Anything is a little better than a sheet of plywood.
Quick Reply: Who uses a drop in bed liner?
