Ford F-350 Pulling 9 Tons of Lumber Proves Torque is King
By -
lumber
A lot of people have been raising their eyebrows and harumphing at the torque numbers available in the next-generation of half-ton diesels like the 2017 F-250. The idea that a person might need, or find use for, 925 lb-ft of twist is hard to comprehend. At least, it is until you understand that people have been doing stuff like this for years.
Now, the Ford F-350 7.3-liter Powerstroke made just about 500 lb-ft of torque which is nothing to sneeze at. It’s one of the most-loved Ford trucks there are and probably ever will be. It’s just that when you’ve got nearly 19,000 lbs. of lumber behind your dually, more torque is ALWAYS better.
He mentions that the transmission is a weak point, and that’s true, especially with the earlier Powerstroke diesels. Taking it easy is smart and is probably how that truck has managed be as reliable as it is.
The new motor makes its max torque at some 1800 rpm and pushes it through the new TorqueShift-G 6-speed. Even though the truck pulling lumber in the video seems relatively untroubled, I bet a torquier motor with revised gearing would make moving hauls like his easier and less stressful. Either way, I dig seeing big trucks like this at work.
Head to the forum for more Super Duty discussion here! >>
Video via: [BradyHill1]
How to Guides
View All >
The Pros & Cons of Ford’s Most Popular F-Series Engines (2.7L, 3.5L, 5.0L, 6.7L, 7.3L)
Slideshow: Pros and cons of the most popular Ford F-series truck engines you can buy today.
Read It
Twin Turbocharged 1971 Ford F-100 Looks Rough, Goes Like Hell
Slideshow: A seriously quick, heavily patina'd vintage hauler.
Read It
This 1986 Ford Bronco Has an F-150 Raptor R Powerplant Underhood
Slideshow: Not exactly something you see every day.
Read It
The 10 Best Values in the 2024 Ford Truck & SUV Lineup
Slideshow: We pick the best values in the 2024 Ford truck & SUV lineup.
Read It
