Ford Bronco vs Jeep Wrangler: Ultimate Comparison
The Jeep Wrangler and Ford Bronco resume their decades-long battle for a new generation.
By Brett Foote - July 26, 2023
NEXT
BACK
Familiar Rivals
1 / 9
Aftermarket Support
2 / 9
Off-Road Capability
3 / 9
Driveability
4 / 9
Driver/Passenger Room
5 / 9
Cargo Capacity
6 / 9
Powertrains
7 / 9
Pricing and Availability
8 / 9
Bottom Line
9 / 9
Familiar Rivals
For decades, the Jeep Wrangler and Ford Bronco did battle head-to-head in the showroom, though the latter model wound up going away after the 1996 model year. For the next 25 years, enthusiasts pined for its return, and FoMoCo finally obliged for the 2021 model year, facing tremendous demand for the reborn SUV. Now, this rivalry has been rekindled for an entirely new generation, which means it's time to take a much deeper look at how the two off-road-focused models stack up in more ways than one.
Aftermarket Support
One of the most appealing things about both the Bronco and the Wrangler is the tremendous aftermarket support that both enjoy - one can quite literally customize either vehicle in so many different kinds of ways that it's quite intimidating, in fact. However, given the fact that the JL Wrangler has been around for several years longer than the sixth-gen Bronco, it has a slight edge in this regard - for now, at least.
Off-Road Capability
One thing that Bronco and Wrangler fans debate more than anything is off-road capability, and for good reason - that's what each was built to do very well. Much ado has been made about the fact that the Bronco uses an independent front suspension rather than a solid axle like the Wrangler, which would seemingly put it at a bit of a disadvantage. In reality, however, both vehicles are incredibly capable off the pavement, and results are going to vary by comparison - and the presence of aftermarket parts as well.
Driveability
While off-roading is a fun and popular hobby that many owners will certainly engage in, most will spend the majority of their time on the pavement - meaning that on-road comfort is also quite important. The Bronco holds an advantage in that regard thanks to its aforementioned independent front suspension, though both vehicles are going to be a bit less comfy than the average crossover thanks to their body-on-frame construction and off-road-focused suspensions. Regardless, either makes a perfectly suitable daily driver, albeit with a fuel economy hit to go along with less comfort.
In terms of space, both the Bronco and Wrangler offer up ample room inside for the most part. The four-door versions provide 40.1 inches in terms of headroom in the Bronco and 42.6 inches in the Wrangler, with legroom coming in at 36.3 inches and 38.2 inches, respectively, giving the Jeep a bit more space to stretch out.
Cargo Capacity
When it comes time to stash things in the back, cargo capacity becomes a big focus point for buyers, too. In that regard, the Bronco four-door holds a huge advantage with 35.6 cubic feet of storage space behind the rear seats, which is far more than the Wrangler at 31.7 cubic feet.
Powertrains
Bronco buyers get the choice of two powertrains - the 2.3L I-4 or 2.7L V6 EcoBoost engines, which generate 300 hp and 325 pound-feet of torque and 325 hp and 415 pound-feet, respectively, though the Bronco Raptor ups the ante with the 3.0L EcoBoost V6 and its output of 418 hp and 440 pound-feet ratings. The Wrangler can be spec'd with a variety of powerplants, however - the standard 3.6L V6 that generates 285 hp, the turbo 2.0L four making 270 hp, a 3.0L diesel V6 rated at 260 hp, the plug-in hybrid 4xe powertrain and its 375 hp output, or the 6.4L V8 from the Rubicon 392, which generates 470 hp. For sheer options alone, the Wrangler is a pretty clear winner here.
The Bronco starts out at just under $35k for the Base two-door and goes all the way up to $86k for the Bronco Raptor, while the Wrangler features similar pricing of $35k-$82k. The bigger issue, it seems, is availability - the Bronco remains in high demand and short supply. Though things have improved as of late, one is still likely to find more Wranglers on dealer lots than Broncos at the moment.
Bottom Line
At the end of the day, it's easy to make a case for buying either a Wrangler or a Bronco. Both offer a dizzying array of configurations, trim levels, and options, both are incredibly capable off-road and viable as daily drivers, and each is pretty practical, to boot. At the end of the day, it really boils down to personal preference, whether that be in regard to styling or brand loyalty. To us, at least, the Bronco is the better-looking and more compelling vehicle, but we certainly can't blame Jeep folks for sticking with their Wranglers, too.
>>Join the conversation about the Bronco and Wrangler right here in the forum.
NEXT
BACK
