Bagging a 65?
Bagging a 65?
Little help!!
I have read almost all the various listings but no one has provided good concrete material. Is it better to change the subframe (Camaro, Crown Vic, etc), swap in a Fatman IFS system, use parts from another Ford family member, or just simply bag the existing IBeams? I know the problems with Camber but I want to know the opinions of my fellow F100 lovers!!
PS
Is there any other alternatives that have been attempted with success?
PS
Im in the process of putting a front clip out of a '73to'87 chevy truck into my '66 f100. this will still be some work but it wont be as bad as the camero or crown vic clips. less fab work to make the radiator support fit because the measurments are pretty close plus we cut the center of the cross member and narrowed it so that my wheels will fit the fender better.I checked on the I beams and just could'nt get the drop I was looking for with this front end I can go with bags,drop spindals,springs,A frames etc.... hope this helps
Airbags won't work on Twin-I-Beam. You need to purchase drop beams or swap the front suspension for something else. Popular options are Dakota, Diplomat, Aerostar and Crown Vic. Mustang II based suspensions are not well thought of for this application. The Dodge choices will also match your bolt patter for the rear to the best of my knowledge.
Chevy parts? Not going to make many friends here with that choice and the bolt pattern is different. But, to each his own.
sorrry for the spam... but everyone loved my chevy bumper on my slick... and he can still be my friend even if everyone flames him...
I disagree with the comment about the Mustang II front end. I have one on my 66F100, with a fatman sway bar, and QA1 coil over springs. I have not got to drive it since the spring swap as it has been in the body shop but before that it drove great and I can only expect it to get better with the new coil overs. But like ddavidv said...to each his own. Also, I must say I feel sick everytime I hear someone mixing Chevy crap with Ford but that is my opinion...and you know what they say about opinions!
Well, in response to your opinion I have started a gallery. The truck is currently in the middle of being restored again so I posted a pic of the engine, a rear shot of the new mustang tank, the speedometer that I restored, the before pic with the sunset in the background, and a pic of the front end. Let me know what you guys think!!!
Well,
I just got a response from Heidt's who make mustang II front ends, and they told me they do not carry one for the 65 F100's due to the fact of them being to Front Heavy! What does that mean???
However, I did talk to a great person by the name of Brett from Fatman Fabrications (His truck is the teal 67 F100 on the website) and they have a kit specially made for the 65 F100 for $2800.00 (Stage 4 which includes cups for airbag setup). He was so Kool. He sent me the build sheet for the Mustang II swap and highlighted all the parts I was interested in on the Catalog he sent me. He was a great help but that is a lot of money.
My question, Is the 65 and on F100's more front heavy than the previous F100's? Does it really make a difference? Has anyone put a Mustang II front end in their F100?
PS
I am also one of those guys that does not believe in mixing GM and Ford. I hate to see a Perfectly built 56 F100 and find a 350 or 454 inside it. If you want a Chevy then Buy a Chevy! I love all classic trucks, be it GM, Dodge, Ford, Studebaker etc., a classic is still a classic!!! I just prefer FORD!!!
PS
Really
And please tell me just how many FORD parts are on the fatman kit?
The issue is with gross registered vehicle weight. A slick dressed is around 4000 pounds depending on the options. add a big block AC and all other kinds of things and the weight goes up. If the truck weighs 4000 and you add another 1000 you all ready are at the stock limit of the regestered weight and you are not in it. Not fun getting tagged by john law as being over weight on the axles.....
Trucks also have horrible weight transfer under braking. Basically about 90 percent of the trucks weight is transfered to the front suspension. One heck of a load is delivered to the front suspension.
MIIs were designed by ford to be a 56 inch width track on a 3000 pound econobox. a slick is a 60 inch track. Current MIIs offered rework the control arms and mount points to compensate for this.
After market MIIs mearly use the design concept and basic geometery and not much else.
Garbz
Garbz
so who ever said you cant bag a truck on ibeams, your wrong.
Bagging beams just takes a little creative thinking as to just how one would mount it and rework the upper perch. other wise the bag just replaces the stock coil spring.
Largest issue is the huge camber change incurred once the air is let down. And there is not much that can be done with that its a live with it thing.
I beams are LOOOOONNNNNNGGGG and have a huge arc through the king pins on any travel.
I like the force it to fit!.....
Garbz
Garbz
