What have you done to your truck today?
Old 04-10-2008, 08:26 PM
StealthWyvern's Avatar
StealthWyvern
StealthWyvern is offline
I stole this thread idea from my mazda forum.
Today I painted 2 rims off of my truck and primed 1. I will complete the other rims on my next day off. Enjoy here is a link with before adn after pictures. Well one rim completed and what the other rims looked like beofre I painted them.
- StealthWyvern's Image Gallery=
Old 04-10-2008, 08:51 PM
Kista20's Avatar
Kista20
Kista20 is offline
haven't done anything today to it but yesterday I replaced some instrument bulbs and then the other day I took out the polk speakers I installed after I bought the truck and replaced them with some infinity kappa ones in the doors. Also I have new wiper blades I need to put on then get it inspected in the next week or two.
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
Today I just drove it. Gave the 4x4 a good test as we'd got probably 6 inches of wet snow when I drove home.
I haven't done anything to my daily driver 95 for quite awhile. It needs a major cleaning when the weather gets nicer. And there's a oil pan gasket and timing cover gaskets waiting in the garage.
Last weekend on my 97 I finally got the spare tire mounted underneath where it should be (yes it's a PITA but it's out of the way). Had the windows professionally tinted on Friday. I don't have the patience to do it myself and be happy with it. The weekend before I put new door speakers in and changed the fuel filter. The door panels had never been off and other than breaking one clip it went perfect. The plastic behind them still looks brand new. On the speakers I even took the factory connectors off the blown speakers and soldered them on the Kenwoods. Cutting any factory wire is a pet peeve of mine.
Old 04-10-2008, 09:18 PM
Noneshere's Avatar
Noneshere
Noneshere is offline
Lol.......What I've done today.....Hummm
Today.........I broke the leaf springs off the axle and ground down the rust ,painted both the springs and 3" mounting brackests.
This is a 2wd 1991 F150 super cab , I am replacing the suspension with a 1982 f-350 2wd Dually suspension.
It all started with an AOD transmission swap to a HD C6. (this went clean , with the exception of having to replace the steering column of a 4 speed selector to a column with a 3 speed selector)
In my parts hunt I found an f350 frame and suspension for free.
After doing a little mesuring and research I found Ford used the same frame from 1980 -1996. The mounting brackets were different sizes. the frames have all the holes in the same spots though. So with a 4" grinder I started cutting the rivits off and swapping the brackets. I have drilled the frame and brackets out for 1/2" bolts. The front end went in clean also. The rear is a bit of a chore .
This Axle is a Dana 70 1-ton , with a 4:10 gear set. with the addition of a posi-locking differental . The truck will be quite a tractor when finished.
It's definitely not going to be a daily driver, but when it's application is needed in life , it should be plenty.
I really want to finish it off with a set of 24.5" Bud Hub Piloted semi-truck rims all the way around. 24.5" rims with factory tires are around 41" tall. The mileage on these tires is outragiously high @ 350,000 . And the rims and tires should not be to hard to find used.
It's just like building models when I was younger , just on a much larger scale today.
Here is some photos of the process :
Flickr: Photos & Video from noneshere
Old 04-10-2008, 09:23 PM
donnor's Avatar
donnor
donnor is offline
Butchering is for meats - not truck wiring.
Dittos on that sentiment! I want to both scream and cry when I go to some salvage yards and see how some people dismantle vehicles. Ebay listing pictures too often show the same callous disregard.
dn.
Old 04-10-2008, 09:24 PM
86F150302's Avatar
86F150302
86F150302 is offline
I put in NGK V-Power plugs
Old 04-10-2008, 09:29 PM
Kista20's Avatar
Kista20
Kista20 is offline
I put them in my 300 as well, good plug
Old 04-10-2008, 09:33 PM
donnor's Avatar
donnor
donnor is offline
Torino on steroids?
Noneshare:
The Starsky & Hutch paint theme is a nice touch! I have not seen that before on a truck.
dn.
Old 04-10-2008, 09:35 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Today I reset my idle (new motor's starting to loosen up)
Welded up the latches on my jobbox.
And put $142 worth of regular in it.........
Old 04-10-2008, 09:47 PM
12secondstang's Avatar
12secondstang
12secondstang is offline
Yesterday, I drove my truck for the first time since mid October before winter. While out it got a good bath to get the garage dust off.
Old 04-10-2008, 09:51 PM
gweeds's Avatar
gweeds
gweeds is offline
Yesterday I spotted a little off road path while my girlfriend and I were driving (in separate cars) to Subway. Almost got high centered (well, I did, but I got out of it, carefully...). Would have been really embarrassing to have her pull out the f250 with her Dakota... But hey, she actually followed me down the trail, so major kudos...
Old 04-10-2008, 11:03 PM
Scndsin's Avatar
Scndsin
Scndsin is online now
I used my tailgate as a potting bench.
Old 04-11-2008, 08:30 AM
cjben's Avatar
cjben
cjben is offline
I looked out behind the garage to make sure it was still there and make sure some punk hadn't vandalized it.
Old 04-11-2008, 09:58 AM
bad96's Avatar
bad96
bad96 is offline
got the headers back on and hopefully ill have my pushrods (only thing i need)by sat. and can fire it up with the new heads
Old 04-11-2008, 10:07 AM
icrman's Avatar
icrman
icrman is offline
I did all my work from December to about 2 weeks ago. It was a slow when you got time sorta thing. I found a replacement for my 460 that was fried by the previous owner, due to a water pump failure. It was drove a long ways with no coolant. The replacement an advertized low mile unit, which it looked like it was, had a rod bearing ready to fail. So did a refresh overhaul to it. And toyed with the idea of doing the transmission since it was out. Decided not to, it works okay. Then I did the stuff listed in the signature, it took along time, to route stuff, and use flex conduit etc. I don't see how the outfits that sell those things can do the job so inexpensively. I guess they slam bam it, and cut corners.
Quick Reply: What have you done to your truck today?
