48 Truck
48 Truck
I live near Perth in Western Australia.
I recently purchased a 1948 truck.
Following are the details I have found.
Is this a 1948 model and what capacity engine is it.
Any help would be appreciated.
Regards,
Mal
Details:
Plate in cab:
Model T58100
Gross Vehicle Weight 18,000lbs
Total Vehicle And Load 161cwt
Ford Motor Company Of Australia
Engine bay Firewall:
7C81
900
Cylinder Heads:
8BA
Made in Canada
Valley Cover:
C8BA
C8BT
6250
Regards,
Mal
Details:
Plate in cab:
Model T58100
7C81
900
Cylinder Heads:
8BA
Made in Canada
Valley Cover:
C8BA
C8BT
6250
48 Truck
Mal, The vin number would be on your truck's title. It is also stamped on the clutch housing, and can be seen when the transmission cover is removed. It should also be stamped on the frame rail (I believe on the driver side). If your truck is a 1948, the first character of your Vin. # would be an "8".
Kenny
Kenny
48 Truck
I found the vin on my 48 F1 on top of the frame near the front motor mount, but on the passenger side.
The vin was located on the Data plate on the firewall, the Rating plate on the glovebox door and on the frame rail. I did NOT find it on the tranny.
Your GVW would correspond to something like an F7, 2 1/2Ton. Is your wheelbase 135 or 159 inches?
If your vin is similar to US models, it should be something like 88EQ******
Tim
Tim
thanks
cheers Stuart
efie77
07-26-2015 09:36 AM
