2024+ Ford Raptor Gen 3 Refresh Dual 40s Light Bars PRO by M&R Automotive
Hey guys,
With our upgraded our website live, it’s even easier to upgrade your Raptor with our most popular light bar kits… and TWICE as nice! Introducing the M&R Automotive Ford Raptor Gen 3 Refresh Dual 40s Light Bars PRO.
This kit is super easy to install:
1) No drilling. Complete bolt-on.
2) You do need to remove the grille but we provide step by step video instructions for an easy DIY install
3) Lifetime warranty
4) Can tap directly into your AUX switches if equipped. If not we have a perfect solution (M&R Wireless Harness)
Fits: 2024–2026 Ford Raptor Gen 3
Yes! This will fit the Ford Raptor 37 and R package with modular bumper.
- 1 light bar below "FORD" and 1 light bar above "FORD"
- Must remove grille
- No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
- WILL NOT interfere with active grille shutters. Our light bars are slim and the metal bracket is designed to be in front of the shutters.
- Doesn't interfere with radiator air flow
- Metal bracket is powder coated black
Choose light output color:
Each PRO bar is dual-color — a main beam plus a soft amber DRL (daytime running light) backglow.Option 1 — White + Amber DRL
- White LED — Super bright, crisp white beam with plenty of light for any adventure. Off-road use only — it blinds oncoming traffic and isn't street-legal.
- Amber DRL — Purely cosmetic amber glow. Street-safe — gives off little light and won't blind oncoming traffic, so you can run it on the road.
- Yellow LED — Cuts through dust, fog, snow, and rain better than white light. Ideal for poor driving conditions. Off-road use only.
- Amber DRL — Same cosmetic amber glow. Street-safe — won't blind oncoming traffic.
- Combo Pattern: combined spot and driving optics offer a balance between distance and width
- Uses a TIR (Total Internal Reflection) lens, which is different from the conventional optics parts, which lose some light internally and produce glare. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
- Higher light efficiency: brighter, longer irradiation distance
- Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant.
- Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
For More information on the M&R Automotive Ford Raptor Gen 3 Refresh Dual 40s Light Bars PRO, click HERE
If you’ve bought this kit, post your pics and let us know what you thought! We always appreciate your feedback!
