Too Hot !!
Old Yesterday | 10:41 PM
ROBERT FOUTS's Avatar
ROBERT FOUTS
5th Gear
Too Hot !!
I have a 2025 f 250 xlt with the 7.3 Goszilla--The transmission temp runs in the 190 range under normal conditions, and 220-230 when towing. The truck has only 7k miles currently--Is there any aftermarket pan or cooler which can be installed to bring this down? I've been told this is normal, and the fluid is designed to handle this , but it just does.t seem normal--any thoughts?
Old Yesterday | 11:59 PM
2019RRSDLARIAT's Avatar
2019RRSDLARIAT
Unfortunately it is normal for those 10 speed transmissions. The ULV fluid is designed to handle higher temperatures so it should not affect the longevity. PPE does make a transmission coolant bypass valve that will lower it is by at least 20 degrees or more.
https://ppepower.com/products/transm...KLZQR5GFhVOxOP
Hope this helps, or you could live with it. Whatever you prefer.
Shadowrider123's Avatar
Shadowrider123
That's normal. This is one of those it aint broke moments.
Old Today | 12:37 AM
Kameron Rice's Avatar
Kameron Rice
normal, mine gets up to 232. A deep dish pan will make no difference, just take a few extra minutes to get up to that temperature. It’s thermostat controlled.
Old Today | 12:42 AM
1olddogtwo's Avatar
1olddogtwo
I run 240+ hours on end, 100's of miles a day, Don't sweat it.
Bvill01
Jul 6, 2014 04:47 PM
stimm32
Apr 6, 2013 05:03 PM
bkuuz1
Aug 23, 2008 03:44 PM
eric777
25
May 22, 2007 07:34 AM
997.3okie
Sep 26, 2005 10:44 AM
