Sponsored by: Real Truck
2004 F250 Diesel Charging Problems
Old Today | 08:21 AM
RobMF250's Avatar
RobMF250
3rd Gear
I have an intermittent issue with Charging. Battery light on dash goes on and off and a couple times I've had to jump start or charge the batteries to get it going. I've done a lot of research on this site and elsewhere and I think I might need to replace / upgrade my alternator but would like some feedback before I pull the trigger. I believe the alternator is the original 110 AMP stock alternator. I live in Florida so AC is on all the time. Here is the situation and the testing I've done.
- Batteries are both 4.5 years old
- Disconnected both batteries, thoroughly cleaned terminals and posts. Added a little bit of distilled water to one battery. Levels were slightly low but still covering plates.
- have disconnected both batteries and charged on automatic batter charger and both successfully charge.
- ran alternator test from charger and came back good.
- Checked serpentine belt and it looks good and doesn't feel loose.
Checked all the voltages as follows:
  • Power off / cold: 12.5 volts on both batteries tested across terminal, positive terminal and body ground, alternator hot post to alternator housing, alternator hot post to both batteries negative terminals. Same 12.5 volts everywhere.
  • Start Truck and test immediately: 12 volts on each battery and 12 volts at alternator.
  • 5 mins after start: 13.7-13.8 volts one each battery, same at alternator and same from alternator hot post to alternator housing and to both negative battery terminals.
  • With MAX AC on and headlights ON: 12.9 volts on all test spots shown above.
  • With MAX AC and headlights OFF: 13.4 volts at alternator and Passenger side battery across terminals. 13.3 volts at drivers side battery across terminals.
  • After idling for about 10 minutes tested at 2200 RPM: Both batteries 13.7 volts across terminals. At alternator 13.9 volts from hot post to alternator housing.
It seems like the alternator is putting out but I thought I'd see something above 14 volts while running after warming up. Since the batteries charged fine and they are reading 12.5 volts cold and I've only had to jump it one time it doesn't seem like they are a problem but they are 4.5 years old.
Any feedback on the situation would be appreciated before I start spending money on batteries and alternators. I'd also appreciate any recommendations on alternators if I need one. I think I'd upgrade to a 135, 140 or 180 AMP as I don't tow a lot these days with the truck. I see all the 200+ AMP options out there but I think that would be overkill for my needs. I think the AC is probably my biggest draw.
Thanks in advance for any feedback.
Old Today | 09:41 AM
Pikachu's Avatar
Pikachu
Have the batteries been load tested? 4.5 years is on the old side for batteries. Check the alternator for AC ripple. Set your multimeter to AC volts and read from the alternator frame to the output lug. You want to see close to 0 VAC, but up to 0.5 VAC is acceptable.
Old Today | 12:04 PM
RobMF250's Avatar
RobMF250
3rd Gear
Pikachu, thanks for the advice. I appreciate your help. I will do the AC ripple test. That's a new one to me but I googled it and it make sense. I haven't taken the batteries in for a load test but will likely do that. I might buy new ones anyways as I know they are getting a bit old with the load the 6.0 puts on them plus the Florida heat doesn't help. I'll post back after testing.
86AC
Dec 5, 2018 10:24 PM
cowmilker08
Feb 20, 2017 09:08 AM
KDAVID1
Jun 17, 2015 05:38 PM
Calheader
Nov 19, 2014 02:30 PM
sprint406
37
Feb 21, 2012 06:25 PM
