2004 Ford Ranger: loud clicking noise from engine area
Came home today and as I was pulling into the driveway a loud clicking sound started coming from the engine area. Truck just came out of service after shop replaced the thermostat housing. Drove around 60 to 70 miles today with no problems... no noise.
Will investigate tomorrow. Unless something obvious pops up... like the fan is hitting something, I will remove the serpentine belt, first, to see if the engine runs quite. That will eliminate the possibility it is coming from the engine itself. Then, I can try and turn the water pump and the alternator by hand to see what that gets me.
Then go from there.
Does this sound like a plan or ??
Seeing as you have a 4.0, you might be hearing timing chain slap. If the sound is coming from the right front of the engine it could be the driver’s side primary chain guide or tensioner. If it’s coming from more of the rear of the engine on the passenger side it might be the passenger primary chain. There is also a jack shaft chain lower down on the front and sometimes a balance shaft chain near the underside of the engine. You can pop off the valve covers and get a look at the primary chain guides and tensioners. And you can look at the roller followers and hydraulic lifters there too.
