About to give up on my 450, looking for suggestions
Old Yesterday | 12:21 PM
cpobst's Avatar
cpobst
Pretty much since new I've had a vibration in the rear between 40-47mph. I blew it off for the longest time. Every other speed is really smooth and it's a different vibration than say hitting a pothole and feeling it resonate through the truck. I can be on a perfectly smooth road and anything below or above the mentioned speed is fine. It has done it with 4 sets of tires including the factory ones. It's going to the dealer this next week but I'm just curious if anyone else has had this issue and fixed it? I've had these current tires balanced 4 times, tried balance beads and centrimatics with no change. I'm wondering if it's driveline related but what would cause that only at those speeds? I'm almost to the point of trading it in and getting a 350. Thanks
Old Yesterday | 12:26 PM
ongrade's Avatar
ongrade
Trailering
Originally Posted by cpobst
Pretty much since new I've had a vibration between 40-47mph. I blew it off for the longest time. Every other speed is really smooth and it's a different vibration than say hitting a pothole and feeling it resonate through the truck. I can be on a perfectly smooth road and anything below or above the mentioned speed is fine. It has done it with 4 sets of tires including the factory ones. It's going to the dealer this next week but I'm just curious if anyone else has had this issue and fixed it? I've had these current tires balanced 4 times, tried balance beads and centrimatics with no change. I'm wondering if it's driveline related but what would cause that only at those speeds? I'm almost to the point of trading it in and getting a 350. Thanks
Driveshaft speed is tied to road speed, I bet you have a driveshaft that is not balanced correctly.
Old Yesterday | 02:25 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
@cpobst
Do you experience the same vibration, at the same road speed, when towing a 5th wheel as when empty?
Or does the vibration disappear, or hit different, when loaded?
Old Yesterday | 02:29 PM
cpobst's Avatar
cpobst
Originally Posted by Y2KW57
@cpobst
Its not as noticeable with our 5th wheel in tow but I can still feel it.
Old Yesterday | 02:45 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Is there an odd looking vibration damper installed on the roadside mounting bracket for your rear receiver hitch?
Old Yesterday | 03:00 PM
cpobst's Avatar
cpobst
I think I know what you are referring to, I just looked and no I don't have anything like that. Should I?
Old Yesterday | 03:44 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Take and post several photos of your roadside rear frame rail hitch bracket.
We are not only looking for mounting holes on the rear receiver hitch side plate (roadside only), we are also looking for witness marks around those mounting holes, where a vibration damper may previously have been bolted, but was removed.
Old Yesterday | 03:46 PM
cpobst's Avatar
cpobst
Mine never had one, I bought this truck new. Here's a few pics though.
Old Yesterday | 04:21 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
@cpobst
Build date of your truck please, per Federal Certification Label on door jamb.
Also, Warranty Start Date.
Old Yesterday | 04:36 PM
jimzpsd's Avatar
jimzpsd
You can also inspect the rear driveshaft for where the balance weights are spot welded onto the tube. You may have lost one (I did on my '17) making out of balance at a certain rpm. I noticed a square rust spot on my driveshaft and then spotted the two weld marks where the weight used to be.
Old Yesterday | 04:42 PM
cpobst's Avatar
cpobst
@cpobst
Build date 8/21. Warranty start date also 8/21. Whatcha doing with all this?
Old Yesterday | 05:29 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I took delivery of my 2022 in Aug of 2021.
The (build) date on (my window sticker) says 8/12/21.
Print this out, and bring all paperwork from all prior visits to wheel and tire shops, driveline shops, and previous Ford dealers when you go in next week for your appointment.
The dealer can look up in OASIS what used to be called HVBOM (this has a different acronym now) that identifies every part that your VIN should have.
Ford has fitted vibration dampers to the F-450 pickup since the model was first introduced in 2008.
Note that the damper is only fitted to F-450 pickups with 19.5" tire and wheels, because the F-450 chassis cabs with the same tires and wheels still have a different frame, and a different suspension, and therefore have a different resonant frequency response.
When Ford changed the pickup frames for the 2017 model year, Ford changed the part number to the F-450 pickup damper (HC3Z), in calendar year 2016, for model year 2017 and up, until February 2023.
Before you give up on your 450 pickup, try this damper. If your truck was supposed to have it and never did receive it, then the right thing for Ford to do would be to install one at no cost.
Old Yesterday | 05:42 PM
cpobst's Avatar
cpobst
Thank you, I'll do that and I'll follow up here on what if anything they do. Also I'll check the driveshaft for missing weights. Thanks guys 👍🏻
Old Yesterday | 06:24 PM
cpobst's Avatar
cpobst
Has anyone been able to get it installed at no cost? Even if I have to pay and it works it'll be worth it.
rgdrake1
2009 - 2014 F150
Sep 4, 2016 08:41 AM
zamunda
1997 - 2003 F150
34
Apr 3, 2010 12:30 PM
kobby71
2004 - 2008 F150
28
May 23, 2006 09:53 PM
shughe40
23
Jul 10, 2005 03:38 AM
TLAM
Nov 26, 2004 04:10 PM
