Stuck Dipstick tube
Old Jun 12, 2026 | 09:52 AM
willb1's Avatar
willb1
Stuck Dipstick tube
I’m installing ramhorn manifolds and need to get the dipstick tube out. It is stuck stuck stuck. Dont want to damage it.
Any suggestions? (pull harder)
I could drop the oil pan but not sure if that is even worth the trouble. Also swabbing acetone to loosen any rtv that may have been used.
Thanks
Old Yesterday | 01:27 PM
KO1960's Avatar
KO1960
A bit of heat may help. Dipstick tubes are notorious for being difficult to remove even when the engine is on a stand.
Old Yesterday | 04:44 PM
willb1's Avatar
willb1
Finally got it but not without a slight crack. I’ll patch it up with rtv and replace it later. Second time should be easier.
Thanks for the replies.
Old Yesterday | 08:30 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
My 2 cents : if you are able, use JB Weld or similar and not silicone. Then, keep looking for a used undamaged one.
Better yet, John Mummert will sell you a new stainless one that will clear when using ramhorn manifolds.
Old Today | 07:24 AM
skidoorulz's Avatar
skidoorulz
I bought the Mummert one when I bought my ramhorns from him. It is about 4 inches shorter than what the factory truck tube is.
Old Today | 09:24 AM
ibuzzard's Avatar
ibuzzard
Was that a problem? Have to change dipsticks? Would the stock tube/stick have worked out fine? On my 59, I recall just making a tweak to the tube and all was perfect.
Old Today | 10:09 AM
kenny nunez's Avatar
kenny nunez
Dip stick tube
Since most of them are made from 3/8” tubing I have had to make some by first having a known amount of oil in the pan. Then starting with a longer piece using a mini tubing cutter and checking with the dip stick cutting a little at a time until the stick reads in the range.
gordo200
Apr 25, 2022 07:57 AM
ranger140892
Jun 2, 2018 11:11 AM
P4IN COMM4NDO
13
Oct 28, 2016 07:15 PM
Highridge
Mar 13, 2013 07:50 PM
RaulLopez
18
Sep 28, 2009 01:22 PM
