Can someone help ID this part? 95 460
Old Jun 12, 2026 | 08:35 AM
apnea_addict's Avatar
apnea_addict
Hey everyone,
I was hoping you guys could help me identify a part off of my 95 f350 with a 460 engine. I had the short block rebuild and this came back in a box of spare parts.
Thanks for the help!
Old Jun 12, 2026 | 09:34 AM
xlt4wd90's Avatar
xlt4wd90
Pilot bearing. It goes into the end of the crankshaft to support the front of the transmission input shaft.
Old Jun 12, 2026 | 09:57 AM
apnea_addict
Thanks!
Old Yesterday | 10:19 AM
manicmechanic007's Avatar
manicmechanic007
That one is missing the needle bearings inside it
Good thing, them removing it for you
They are not easy to get out
Last 460 I put a clutch in; I used white bread with crust to get the old one out
Old Yesterday | 10:37 AM
xlt4wd90's Avatar
xlt4wd90
Could that have been a bushing instead of a bearing?
In either case, I would get a new bearing, as they tend to work better. Get the proper size for your transmission; measure the ID of the hole on the end of the crank shaft, and the OD of your transmission's input shaft.
I did the white bread trick as well, on a bushing.
Old Today | 12:25 AM
manicmechanic007
The bushings were / are all brass and that hole is too big for an input shaft
It's missing the roller bearings and the stainless steel sleeve that holds them
79F150400M
Feb 2, 2026 09:21 AM
Dougie Fresh
May 11, 2024 11:36 AM
djc1481
Mar 29, 2019 12:02 PM
F460bigbore
20
Aug 12, 2018 09:06 AM
RollsBack
Apr 26, 2016 09:21 PM
